As an example, see the attached screenshot of unmatched albums.
Everyone of those albums can be found at MusicBrainz. In fact, I added all of them myself. I believe they are the only release in the “Release Group,” so there can be no confusion that It could match a different release version.
In all cases, if I choose “Match” (or in some cases “Fix Match”), the proper match is shown instantly as the first selection, at 100%. The cover art I uploaded to MusicBrainz (scans of the 45 RPM record label) are shown as the available cover art.
In addition to the scheduled tasks, the music scanner also appears to scan the unmatched albums each time a new album is added. I added two albums, and two separate scans of the library were initiated. Every unmatched album directory was re-scanned, apparently for no reason, as nothing was matched. From the Plex server logs, 2 of the unmatched albums, with their associated MusicBrainz link:
Album “The Circle is Small / Sweet Guinevere” by Gordon Lightfoot
MusicBrainz link: https://musicbrainz.org/release/732f459a-9004-4805-9b13-07691fafe282
Jan 01, 2020 23:56:24.062 [15284] DEBUG - Scanner: Processing directory F:\Plex Videos\Albums\Gordon Lightfoot\The Circle is Small (parent: yes)
Jan 01, 2020 23:56:24.066 [15284] DEBUG - Skipping over directory 'Gordon Lightfoot\The Circle is Small', as nothing has changed; removing 2 media items from map.
Jan 01, 2020 23:56:24.067 [15284] DEBUG - Activity: updated activity 32b1c0b2-a940-4d07-a5a5-0c32226b37a5 - completed 5.2% - Scanning Music & Videos
Jan 01, 2020 23:55:57.467 [15284] DEBUG - Scanner: Processing directory F:\Plex Videos\Albums\Gordon Lightfoot\The Circle is Small (parent: yes)
Jan 01, 2020 23:55:57.479 [15284] DEBUG - Skipping over directory 'Gordon Lightfoot\The Circle is Small', as nothing has changed; removing 2 media items from map.
Jan 01, 2020 23:55:57.480 [15284] DEBUG - Activity: updated activity 14f68326-854a-40c3-8733-4f9ee625213c - completed 5.2% - Scanning Music & Videos
Album “Carolina in My Mind” by James Taylor
MusicBrainz link: https://musicbrainz.org/release/dd661dfa-a788-48d2-a6c4-84fa56f82c40
Jan 01, 2020 23:55:59.595 [15284] DEBUG - Scanner: Processing directory F:\Plex Videos\Albums\James Taylor\Carolina in My Mind (parent: yes)
Jan 01, 2020 23:55:59.621 [15284] DEBUG - Skipping over directory 'James Taylor\Carolina in My Mind', as nothing has changed; removing 2 media items from map.
Jan 01, 2020 23:55:59.622 [15284] DEBUG - Activity: updated activity 14f68326-854a-40c3-8733-4f9ee625213c - completed 7.4% - Scanning Music & Videos
Jan 01, 2020 23:56:24.906 [15284] DEBUG - Scanner: Processing directory F:\Plex Videos\Albums\James Taylor\Carolina in My Mind (parent: yes)
Jan 01, 2020 23:56:24.910 [15284] DEBUG - Skipping over directory 'James Taylor\Carolina in My Mind', as nothing has changed; removing 2 media items from map.
Jan 01, 2020 23:56:24.911 [15284] DEBUG - Activity: updated activity 32b1c0b2-a940-4d07-a5a5-0c32226b37a5 - completed 7.4% - Scanning Music & Videos
My interpretation of the logs is probably not very accurate. But I’m pretty sure I see that the unmatched albums were scanned, and nothing was done.
So a couple of questions:
Why bother scanning the unmatched albums during the scheduled tasks if available matches are not applied?
Why scan all of the unmatched albums every time new media is added? The server is configured to only scan the folders that have changed.
I would appreciate any insight. I actually like the new music system, but there seems to be a lot of bugs that are basically ignored.
Attaching logs, hoping someone will give me the correct interpretation, and a way to “match” that isn’t completely manual. Thanks in advance.
Plex Media Server Logs_2020-01-02_00-38-52.zip (5.3 MB)
