Kodi (Omega nightlies) introduced a Dolby vision compatibility mode to play movies using DoVi Profile 7 as DoVi Profile 8.1. - the conversion happens just in time.
sources:
- [depends][Android] Add base dependencies setup for libdovi by quietvoid · Pull Request #22546 · xbmc/xbmc · GitHub
- [obsolete - now in nightlies] Build - Dolby Vision compatibility/quality improvements
It would be great if plex is able to do the same on-the-fly conversion.
