Server Version#: 1.21.3.4046
Player Version#: 1.13
I’m unable to play Dolby Vision dvhe.05.06 in mp4 container without getting a green tint to the video on Plex on Atv4k connected to an LG OLED b7. The plex client shows “HDR” instead of “Dolby Vision” for the file type, but the TV displays “Dolby Vision” when the file starts playing.
My initial though was that something in my setup didn’t support the dolby vision profile level, however, the same file plays fine connected to the same plex server via the Infuse player.
Here is the mediainfo for the file.
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 6.93 GiB
Duration : 44 min 4 s
Overall bit rate : 22.5 Mb/s
Encoded date : UTC 2020-12-18 08:38:20
Tagged date : UTC 2020-12-18 08:38:20
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.2@Main
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 21.7 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 0)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.109
Stream size : 6.69 GiB (97%)
Default : Yes
Alternate group : 1
Color range : Full
Codec configuration box : hvcC+dvcC
Any advice is appreciated! Thanks.
