Server Version#: 4.59.2
Player Version#: 7.22 (Apple TV 4K first Gen)
I ripped my GoT UHD Blu-rays to my Mac mini M1 which runs PMS. The episode have both the TrueHD Atmos and the compatibility track. The video is Dolby Vision with HDR10 fallback.
Then I play the episode with the compatibility track (AC3) the video will be displayed in Dolby Vision (Direct Play) when I choose the TrueHD track it falls back to HDR10 (Direct Stream).
Is this a bug or a limitation?
Plex Server Dashboard:
Compatibility Track
Video: 4K (HEVC Main 10 HDR) => Direct Play
Audio: English (AC3 5.1) => Direct Play
With TrueHD
Video: 4K (HEVC Main 10 HDR) => Direct Stream
Audio: English (TRUEHD 7.1) => FLAC—Transcodestrong text
Media Info
General
Unique ID : 195096398170915151795045180583211584676 (0x92C633144372FBBABCEF30076BFE4CA4)
Complete name : /Volumes/Media 2/TV Shows/Games of Thrones/Season 8/S08E01 Winterfell.mkv
Format : Matroska
Format version : Version 4
File size : 20.5 GiB
Duration : 53 min 7 s
Overall bit rate mode : Variable
Overall bit rate : 55.3 Mb/s
Encoded date : UTC 2021-07-23 07:43:09
Writing application : mkvmerge v58.0.0 (‘Supper’s Ready’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.3
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, dvhe.07.06, BL+EL+RPU, Blu-ray compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 51.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.257
Stream size : 18.9 GiB (92%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : BT.2020
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Original source medium : Blu-ray
Audio #1
ID in the original source medium : 4353 (0x1101)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Format settings : Dolby Surround EX
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 243 MiB (1%)
Language : English
Service kind : Complete Main
Default : Yes
Forced : No
Audio #2
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 565 kb/s
Maximum bit rate : 6 144 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Frame rate : 1 200.000 FPS (40 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 1.32 GiB (6%)
Language : English
Default : No
Forced : No
Number of dynamic objects : 15
Bed channel count : 1 channel
Bed channel configuration : LFE
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 3 s 320 ms
Bit rate : 87.8 kb/s
Count of elements : 4
Stream size : 35.6 KiB (0%)
Language : English
Default : Yes
Forced : Yes
Menu
00:00:00.000 : Chapter 01
00:01:55.865 : Chapter 02
00:10:56.906 : Chapter 03
00:18:02.706 : Chapter 04
00:25:09.174 : Chapter 05
00:34:44.874 : Chapter 06
00:42:35.553 : Chapter 07
00:51:48.730 : Chapter 08
