Double NAT - External Access
Hi all
I had always problems my PLEX server (Synology).
Then I realized that it is a problem with my router.
I am using a AVM Fritz! 6890 LTE which accesses the internet oder DSL (static IP) and LTE (non-static IP).
I disabled LTE and PLEX is available perfectly.
Is there any chance to configure PLEX OR Synology OR the router that it works with both active internet connections?
Thanks and regards.
I got a very detailled answer from the manufacturer of the router.
They change randomly between the two internet accesses. Bridgeing not possible.
But the DNS address is always done via the fix IP of the DSL account.
Why can PLEX not work through such a Domain name?
Can anybody help me to solve this problem?
