I am seeing 2 covers of the same movie but I only have 1 movie. see attached screen shot. Plex running on DS916 nas and Version 1.12.1.4885. any help appreciated. thanks
Looks Like Collections are showing.
That can be turned off in the Library edit screen or you can delete the collections
as per jjrjr1 and Otto’s statement… what you see are inline collections (see link from Otto).
however it doesn’t appear those are from manual tagging (editing a movie: Tags > Collections; unless you’ve typed those tags in all-caps) or downloaded from The Movie Database (library settings: Advanced > Use Collection info from The Movie Database).
Are those movies of yours MP4/M4V files? If so, check if you can remove the “Album” tag in their embedded metadata and re-scan the library afterwards.
issue resolved. many thanks
