Why do I get doubles (1 movie)
I use a WD MyCloud to store my movies as it has the Plex feature, i’ve never noticed this problem before but now I have, I have multiple movies on the movie page, one that says the year under it, and the same poster that says ‘1 movie’ under it, this doesn’t happen for all my movies, just various random ones, why is this and how can I stop it?
Looks like those dups are collections
https://support.plex.tv/articles/201273953-collections/
Thanks, managed to get them off, but for some reason some are still staying, the one like 21 Jump Street, it doesn’t say ‘1 movie’ under one of them, after going in to them I noticed one of them isn’t even 21 Jump Street, it’s 21 & Over, so why is it loading as a different film :-/ so I now have to go into each one and go into Fix Match to fix them all?
Yes, if the movie is wrong. Though… You can show all collections for a particular library.
collections
Double check that your movie is named correctly outside of Plex, then use the “Fix Match” feature and make sure that you enter the specific data so that the tagging library doesn’t get too confused.
Within Plex, the “Get Info” window is super handy to track a specific movie back to its original file.
Collections are handy if you are planning on sorting all of your DC, Marvel, Jump Streets, etc. together.
Awesome, thank you, that makes sense, i’ll go through and have a sort out, thanks again.
