Downgrade to old iOS Version and turn off updates only for Plex - Howto! - no jailbreak required
Go to:
and just follow the manual step-by-step.
you can skip step 1. the buildnumber you are search is “871812101”. that’s the last version of the old app from January 2025.
i did it on a arm mac and with VMware. after you install iTunes and Charles Proxy, it takes you 10 minutes to do the rest and you have your old plex back! yeah! have a nice weekend.
btw. old version 160MB, new 30MB :roll_eyes:
Disable auto updates for plex app - @Mac user
  1. extract your old plex ipa with the Archive Utility. its stored under:
    /System/Library/CoreServices/Applications/Archive Utility.app
  2. kompress the folder content without the files “iTunesArtwork” and “iTunesMetadata.plist” again.
    again(!) compress only the two folders “Payload” and “META-INF”
  3. rename zip extension to ipa
  4. delete installed plex app from your iOS device
  5. drag and drop plex app from step 2/3 to your iOS device in finder. drag and drop works only with cable
Disable auto updates for plex app - @Win user
How do i revert back to OLD IOS APP 4/30/2025
Not a fan of the new Plex app on iOS: How do we downgrade?
On old server, now cannot access Plex iOS
Plex iOS app is now forcing transcoding of H.265/HEVC files that previously played via Direct Play,
New iOS Plex Experience - Can't Download Shows/Seasons
Live TV Issue "Error Occurred : A server with the specified hostname could not be found."
Downloads Missing
New Experience Public Release Feedback
File is Unplayable. DoVi (Profile 5) color space is not supported
Tv show downloads functionality broken in new Plex
Releasing the new app was a crazy decision
What happened to "all your media in ne place"?
App Updated, No Libraries to choose? Continue Button greyed-out
Thanks Devs, Designers, and Money Men of Plex
New IOS app is big step BACKWARDS
Why have you people ruined Plex?
New iphone app 2025.14.0
New IOS App - Can't Cast To Chromecast
Picture in Picture bug in the new iOS Plex app
Playback Issue on iPadOS with New Experience
No Libraries Found, Cannot Connect to Server? - New iOS app
New "experience" is dreadful. Really sorry I bought a lifetime pass
AirPlay missing from enshittified version of iOS app!?
Paid iOS App now forced subscription?
This new android app is awful, where can I download the previous version?
Download unwatched episodes. See downloaded series
Please Release a Classic Mobile App Version (Pre-New UI) – It's All Broken Now
IOS user issues
Latest iOS APP Bugs
New App is unusable on iPad pro
IOS plex update Broken - Terrible update
How can I downgrade the iOS app
What do people think of the official response to the terrible New Plex Experience rollout?
Restoring Older Verisons of Plex app on IOS
Sadly, the solution to the new iOS client woes is Infuse Pro
How to downgrade
just make sure to delete the app off your device first or it wont work, was half a sleep when i first tried it
Awesome
I can live again.
thankyou so much!!!
bit of a faff, but well worth it!
have also done this, to (hopefully) stop any updates:
Works thanks all :slight_smile: Your’e the best.
So basically follow OP’s guide. When it comes time to send the .ipa to your phone, then switch over to medium article, build a new app via iTunes that doesn’t auto update, head back to OP’s original GitHub guide and then send that new .ipa via AppManager.
Will check back on “New Experience” version in 6 months once it’s out of Alpha.
Just want to make sure I follow here. If I’m on a Mac, I literally need a windows license (which I’d need to buy) running in a VM like parallels or VMWare to get this thing rolled back?
no. there is a windows test version. I think VMware can download windows itself
Thank goodness for this and the other posts on here detailing this method. It’s slightly fiddly but not too bad and I’ve managed to “upgrade” (downgrade seems inaccurate in this instance!) to the old version and block it from updating. Hopefully it will stay functional for a long time and survive the iOS 19 updates later in the year. No idea why Plex didn’t just push the preview app to the TestFlight beta channel if they really wanted to broaden testers instead of forcing it in the public builds.
For me the link in the instructions here to the old version of Apple Configurator was key to being able to install the app from the payload folder to prevent App Store updates.
Straight away I appreciate how snappy the original apps is. Press and hold on an item and the menu is right there. The new one you do that and you have a spinning circle just for the menu to populate. Crazy.
I’ve disabled auto updates on my Apple TV and Shield Pro but hoping similar methods will appear if Plex end up pushing this monstrosity to other devices.
Thanks, this worked perfectly. The app is finally usable again!
good idea! I have to block internet from my LG TV. finger crossing they don’t touch the plex server. then its game over :worried:
OT: I no longer find iOS updates so desirable either. I’m still on iOS17 because of the photo app
So this is the new plex experience eh? how lovely!!
take a wild guess why…
they don’t care
@guygamer or others that have successfully done this, where were you able to find the old plex IPA file from January? That seems to be where I am running into a road block. I have the latest version of iTunes 12.13.1 installed on my Windows Machine. If I uninstall, and re-install 12.6.5 to allow app download capability, it is not clear to me how the old iTunes will have that app in its record either. I searched my iTunes purchased history on my phone and beside the new Plex app I want to get rid of, the only other trace of a plex app was from 2018. Can someone post the IPA file or share how iTunes 12.6.5 was able to find it on their system a little more specifically - most all online instructions about going back to a prior version assumes you have access to that IPA file which I have not yet found.
I did this and you have to use the Charles proxy app in the steps and modify it to change the version # to 871812101 It will download the app into the itunes folder on the windows machine.
It’s linked to your apple account so sharing it won’t work. Read through the steps a few times and then try it. Once you have the 8.45.ipa downloaded save it somewhere and you can airdrop it again to your phone if it gets overwritten by a new version.
Step 4:
  • Edit Request > XML Text > Replace the current Build version number of Facebook with the Build Number of Facebook v161.0 (826067593) > Execute > Execute. Now iTunes will download Facebook v161.0 instead of the latest version.
old Plex version:
871812101
My apologies, I was not tracking that this process is actually downloading the old version directly from apple and I was thinking it was trying to find it from my old backup or iTunes history.
With that said, I followed the steps and kept getting a iTunes 1008 error when doing step 4 and after entering in the old plex version in the Charles Proxy. If I closed the error and tried to download the app again I would get a Downloading status in itunes that never downloads and I think it is a not even trying as the Download box under the App does not change to Downloading (vs Download or Downloaded) as in other instances. For those that run into this, I uninstalled iTunes and Charles Proxy and re-did all the steps with the same result two additional times. After my last attempt and a couple hours later of the Downloading screen never finishing, I cancelled the download again. I was about to give up when I tried to download the app one more time and the last time it worked. In each case I either typed or copied the plex version and ensured accuracy into the Charles Proxy and cannot explain why it never worked the previous 10-12 times I tried before it finally went through. I would suggest if you get the 1008 error wait a few hours a try it again. I know this is not satisfying and I wish I new exactly why mine finally worked after doing what I am confident was the same each time but just sharing in case it helps.
I have not manually dragged and dropped an app onto my my device before in iTunes but in case others were not clear, once the app in the iTunes 12.6.5 is downloaded as shown in the image below, you plug your device into iTunes so it shows up on the left side panel. You just select the app from the library and drag it over to the side bar where your device is and it downloads it to the phone (even though there is no App section listed within your device)
Worked like a charm. Kudos.
THANK YOU!!! One less source of unnecessary stress in my life.
Just a note to anyone else, I had to close and relaunch itunes after the initial install, for step 3.4 to work.
