Hello, is there a way to download subtitles back from Plex that I uploaded? I know there is no way to export the subtitles if it is downloaded from OpenSubtitles, but does the same apply to the subtitles I uploaded?
I don’t think there’s a way to access those files uploaded through the Plex UI unless you’re willing to dig deep into the server data directory and jumping through some hoops investigating the GUID / movie data paths.
That was possible with the old WebTools (NOT “WebTools NG”).
Although it is very difficult for a newbie to get it running nowadays.
Honestly, that install was dead simple so i am unsure what you define as ‘very difficult’ xD.
Thanks for the link!
