Downloads do not sync with watch status
Server Version#: latest
Player Version#: 2025.13.0, iPhone
When playing downloaded content, the position is only saved when you open the content from the downloads section, not from the main content browser.
Also it seems playing from the main content browser, the downloaded content is not considered. The content will be streamed even if it was already downloaded.
There seems to be a disconnect between the downloads and the main content index. They are not related but they should be.
2025.14 fixes this and is currently rolling out.
2025.14 does sync the download position now. But when I search for an item in offline mode and press play I get an error even if I already have it downloaded.
I have updated to 2025.14 and am encountering the same issue. Playback state when you launch from downloads gets synced to the server/library but it doesnt work the other way around. If you launch playback from the main library and you are effectively streaming, the download does not sync up and it will play from the last time you launched the downloaded file. I have included this feedvacj in a separate post as well.
Still when I search for an item to play that is downloaded, the download is ignored and it is still streamed from the server.
Can confirm this is still happening. Is there a status update on the fix?
Am running on iOS version 2025.23.0 / latest server version and this problem stille exists as described by @ToddLindner
Given there have not been any signifigant changes to downloads since the rollout of new experience it is definitely lookling like this is just what it is going to be.
