@jaconsass
Your logs tell the tale.
Nov 26, 2022 18:27:10.900 [0x14fa3f5fcb38] INFO - Processor: 8-core Intel(R) Xeon(R) CPU E3-1275L v3 @ 2.70GHz
Nov 26, 2022 18:27:10.900 [0x14fa3f5fcb38] INFO - Compiler is - Clang 11.0.1 (https://plex.tv 9b997da8e5b47bdb4a9425b3a3b290be393b4b1f)
Nov 26, 2022 18:27:10.901 [0x14fa3f5fcb38] INFO - /usr/lib/plexmediaserver/Plex Media Server
Nov 26, 2022 18:27:10.837 [0x14fa2c9e9b38] ERROR - [Req#2a8ae/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] Error while decoding stream #0:0: Generic error in an external library
Nov 26, 2022 18:27:10.846 [0x14fa3a374b38] ERROR - [Req#2a8af/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] [hevc @ 0x149872c04a40] decoder->cvdl->cuvidMapVideoFrame(decoder->decoder, cf->idx, &devptr, &pitch, &vpp) failed -> CUDA_ERROR_MAP_FAILED: mapping of buffer object failed
Nov 26, 2022 18:27:10.846 [0x14fa2c3e0b38] ERROR - [Req#2a8b0/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] Error while decoding stream #0:0: Generic error in an external library
Nov 26, 2022 18:27:10.852 [0x14fa3b76fb38] ERROR - [Req#2a8b1/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] [hevc @ 0x149872c04a40] decoder->cvdl->cuvidMapVideoFrame(decoder->decoder, cf->idx, &devptr, &pitch, &vpp) failed -> CUDA_ERROR_MAP_FAILED: mapping of buffer object failed
Nov 26, 2022 18:27:10.852 [0x14fa398cdb38] ERROR - [Req#2a8b2/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] Error while decoding stream #0:0: Generic error in an external library
Nov 26, 2022 18:27:10.868 [0x14fa3cd87b38] ERROR - [Req#2a8b3/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] [hevc @ 0x149872c04a40] decoder->cvdl->cuvidMapVideoFrame(decoder->decoder, cf->idx, &devptr, &pitch, &vpp) failed -> CUDA_ERROR_MAP_FAILED: mapping of buffer object failed
Nov 26, 2022 18:27:10.868 [0x14fa39d6bb38] ERROR - [Req#2a8b4/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] Error while decoding stream #0:0: Generic error in an external library
Nov 26, 2022 18:27:10.878 [0x14fa396cab38] ERROR - [Req#2a8b5/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] [hevc @ 0x149872c04a40] decoder->cvdl->cuvidMapVideoFrame(decoder->decoder, cf->idx, &devptr, &pitch, &vpp) failed -> CUDA_ERROR_MAP_FAILED: mapping of buffer object failed
Nov 26, 2022 18:27:10.878 [0x14fa2cde2b38] ERROR - [Req#2a8b6/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] Error while decoding stream #0:0: Generic error in an external library
Nov 26, 2022 18:27:10.883 [0x14fa2c9e9b38] ERROR - [Req#2a8b7/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] [hevc @ 0x149872c04a40] decoder->cvdl->cuvidMapVideoFrame(decoder->decoder, cf->idx, &devptr, &pitch, &vpp) failed -> CUDA_ERROR_MAP_FAILED: mapping of buffer object failed
Nov 26, 2022 18:27:10.884 [0x14fa3a374b38] ERROR - [Req#2a8b8/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] Error while decoding stream #0:0: Generic error in an external library
Nov 26, 2022 18:27:10.886 [0x14fa2c3e0b38] ERROR - [Req#2a8b9/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] [hevc @ 0x149872c04a40] decoder->cvdl->cuvidMapVideoFrame(decoder->decoder, cf->idx, &devptr, &pitch, &vpp) failed -> CUDA_ERROR_MAP_FAILED: mapping of buffer object failed
Nov 26, 2022 18:27:10.887 [0x14fa3b76fb38] ERROR - [Req#2a8ba/Transcode/4263d6d0-a5a5-437f-a546-b46190a9429a-1/7483ce2f-b469-4100-828d-f0b823044894] Error while decoding stream #0:0: Generic error in an external library
The cuvid... looks like the Nvidia driver entry point.
I can’t see the strart of the transcode session because it’s rolled off the end of the buffer.
I hear a lot of problems with Unraid…
If you look back 2 posts, you see where I suggest Nvidia GPU passthrough into a VM.
The implication / strategy is to install Ubuntu/Debian in that VM with the Nvidia 510.85.02 drivers
In that configuration, unraid does not get involved whereas in Docker you’re relying on Unraid to handle it all.
Running a full VM is likely not desirable, it will confirm where the problem is.
