There is either a configuration error with the DHCP server which assigns your DS920+ its IP address or you have a loose/damaged ethernet cable .
Its network configuration keeps resetting every few seconds. This makes the network unavailable / unreachable . PMS won’t work until it sees a stable network environment.
Dec 06, 2020 07:43:31.913 [0x7f37b4e31700] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 21.603377 seconds: 192.168.1.114 (ARRIS Manageable Device)
Dec 06, 2020 07:43:31.913 [0x7f37b4e31700] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 21.909068 seconds: 192.168.1.166 (DiskStation (DS415play))
Dec 06, 2020 07:43:31.913 [0x7f37b4e31700] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 21.998997 seconds: 192.168.1.167 ([TV] Home)
Dec 06, 2020 07:43:31.913 [0x7f37b4e31700] DEBUG - NetworkServiceBrowser: SSDP departed after not being seen for 28.641716 seconds: 192.168.1.219 (JEFFREY's Fire TV)
Dec 06, 2020 07:43:35.715 [0x7f37b4e31700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:35.715 [0x7f3757a23700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:40.715 [0x7f37b56fb700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:40.715 [0x7f37b4b43700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:45.716 [0x7f3757a23700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:45.716 [0x7f37b56fb700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:50.717 [0x7f37b4e31700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:50.717 [0x7f37b56fb700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:55.717 [0x7f37b4e31700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:55.717 [0x7f3757a23700] WARN - NetworkServiceBrowser: Error sending out discover packet from 169.254.241.148 to 169.254.255.255: Network is unreachable
Dec 06, 2020 07:43:58.252 [0x7f37b7fff700] DEBUG - NetworkInterface: received Netlink message len=1188, type=RTM_NEWLINK, flags=0x0
Dec 06, 2020 07:43:58.252 [0x7f37b7fff700] DEBUG - NetworkInterface: Netlink information message family=0, type=1, index=4, flags=0x11043, change=0x0
Dec 06, 2020 07:43:58.252 [0x7f37b7fff700] DEBUG - Network change.
Dec 06, 2020 07:43:58.252 [0x7f37b7fff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 06, 2020 07:43:58.252 [0x7f37b7fff700] DEBUG - Network change notification but nothing changed.
Dec 06, 2020 07:43:59.408 [0x7f37b7fff700] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_GETADDR, flags=0x0
Dec 06, 2020 07:43:59.408 [0x7f37b7fff700] DEBUG - NetworkInterface: Netlink address message family=2, index=4, flags=0x80
Dec 06, 2020 07:43:59.408 [0x7f37b7fff700] DEBUG - Network change.
Dec 06, 2020 07:43:59.408 [0x7f37b7fff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 06, 2020 07:43:59.409 [0x7f37b7fff700] DEBUG - Detected primary interface: 0.0.0.0
Dec 06, 2020 07:43:59.409 [0x7f37b7fff700] DEBUG - Network interfaces:
Dec 06, 2020 07:43:59.409 [0x7f37b7fff700] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
Dec 06, 2020 07:43:59.409 [0x7f37b7fff700] DEBUG - * 3 eth1 (169.254.241.148) (loopback: 0)
Dec 06, 2020 07:43:59.409 [0x7f37b7fff700] DEBUG - * 1 lo (::1) (loopback: 1)
Dec 06, 2020 07:43:59.409 [0x7f37b7fff700] DEBUG - * 4 eth0 (fe80::211:32ff:fed9:7afd%eth0) (loopback: 0)
Dec 06, 2020 07:43:59.409 [0x7f37b7fff700] DEBUG - NetworkService: Got notification of changed network (first change: 0)
Dec 06, 2020 07:43:59.409 [0x7f37b7fff700] DEBUG - NetworkService: Dispatch network change after two second delay.
Dec 06, 2020 07:43:59.410 [0x7f37b7fff700] DEBUG - NetworkInterface: received Netlink message len=88, type=RTM_DELADDR, flags=0x0
Dec 06, 2020 07:43:59.410 [0x7f37b7fff700] DEBUG - NetworkInterface: Netlink address message family=2, index=4, flags=0x80
Dec 06, 2020 07:43:59.410 [0x7f37b7fff700] DEBUG - Network change.
Dec 06, 2020 07:43:59.410 [0x7f37b7fff700] DEBUG - NetworkInterface: Notified of network changed (force=0)
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - Detected primary interface: 0.0.0.0
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - Network interfaces:
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - * 1 lo (127.0.0.1) (loopback: 1)
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - * 3 eth1 (169.254.241.148) (loopback: 0)
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - * 4 eth0 (192.168.1.220) (loopback: 0)
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - * 1 lo (::1) (loopback: 1)
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - * 4 eth0 (fe80::211:32ff:fed9:7afd%eth0) (loopback: 0)
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - NetworkService: Got notification of changed network (first change: 0)
Dec 06, 2020 07:43:59.411 [0x7f37b7fff700] DEBUG - NetworkService: Dispatch network change after two second delay.
Dec 06, 2020 07:43:59.411 [0x7f37cc3d6700] DEBUG - Network change for advertiser.
Dec 06, 2020 07:43:59.411 [0x7f37cc3d6700] ERROR - Error broadcasting message: send_to: Network is unreachable
Dec 06, 2020 07:43:59.411 [0x7f37cc3d6700] DEBUG - NetworkService: Network change for browser (polled=0), closing 3 browse sockets.
Dec 06, 2020 07:43:59.411 [0x7f37cc3d6700] DEBUG - NetworkService: Setting up multicast listener on 0.0.0.0:32413
Dec 06, 2020 07:43:59.411 [0x7f37cc3d6700] ERROR - NetworkService: Couldn't join multicast group: set_option: No such device
