While adding my Mpeg2 and VC1 keys to the config.txt file i noticed that theres an area to add DTS decoding. However there is nowhere in the raspberry pi store to buy it? Is this non-functioning or is there a workaround. Can i buy the key somewhere
You cannot buy a DTS codec licence, I believe that the Raspberry Pi Foundation were looking into this when they originally launched but the cost proved to be prohibitive. I don't think it will ever happen. You don't really need it because Rasplex will passthrough both DTS and DD to a capable amp.
Regards
Regards
so dose it pass thro DTS HD or TrueHD ?
As far as I have understood it: No
i wish thy can bring an update that can support that
