To accompany the 0.7.1 release here is a pdf file which is a Guide to Audio Settings in Rasplex.
Rasplex Audio Settings V2.zip (576.8 KB)
Now updated following the release of Rasplex 1.6.0
Regards
[Mod edit 2019-03-23: file attachment restored]
Regards
Could you include some Hifiberry instructions aswell. Have a Hifiberry-digi but don’t get a sound out. Is movie supported right now ?
HiFiBerry is music only.
Regards
@NedtheNerd said:
HiFiBerry is music only.Regards
Hi Ned, any hints if hifiberry will be supported for movies in an upcoming release?
Hopefully in next major release.
Regards
Good to hear this Ned, I’ll start looking for one of these then !
Hi Ned thanks for the PDF, but could you add a section regarding analogue audio output and how to boost the signal?
cu V
@Velociraptor said:
Hi Ned thanks for the PDF, but could you add a section regarding analogue audio output and how to boost the signal?cu V
Will have a look at that next week.
Regards
My soundbar gives me the following output
RasPlex:~ # tvservice -a
PCM supported: Max channels: 2, Max samplerate: 48kHz, Max samplesize 24 bits.
AC3 supported: Max channels: 6, Max samplerate: 48kHz, Max rate 640 kb/s.
DTS supported: Max channels: 6, Max samplerate: 48kHz, Max rate 1536 kb/s.
Should i set it at 2.0 with dts and ac3 checked?
Yes that sounds correct.
Regards
After spending a couple of hours trying to get my audio working I found this, up and running in minutes after reading this, should be pinned at the top of the section.
Thank you.
Thanks for the feedback, I will be updating this for the next release which has changes to audio settings.
Regards
Hi, i’m new to Rasplex and wonder if my Sound Settings are correct:
I have this configuration:
RPi connected via HDMI to Amplifier, Amplifier connected via HDMI to TV
and i get the following Information.
PCM supported: Max channels: 8, Max samplerate: 192kHz, Max samplesize 24 bits.
DTS supported: Max channels: 7, Max samplerate: 48kHz, Max rate 1536 kb/s.
DTS_HD supported: Max channels: 8, Max samplerate: 192kHz, Max rate 8 kb/s.
According to the pdf i configured my Audio Settings as follows:
Audio Output HDMI
Dolby Digital (AC3) capable receiver Checked
Dolby Digital Plus (E-AC3) capable receiver Unchecked
DTS capable receiver Unchecked
Support 8 channel DTS-HD audio decoding Checked
Audio output channels 5.1
With this config i should be able to play MKV’s with DTS-HD and TrueHD Audio, correct? Is DTS with this configuration also decoded by Rasplex or will it passed through to the receiver if i Check DTS capable receiver?
The settings you have are OK, however, if you’re playing content with DTS-HD then should you set Audio output channels to 7.1, assuming you have the required number of speakers, if not why are you ripping your media with 7.1 DTS-HD audio, might just as well rip with DTS 5.1 core.
All types of DTS will be decoded to LPCM 5.1 or 7.1 dependent upon number of channels in the source with the settings you have. If you have Support 8 channel checked you should not enable DTS capable receiver.
Regards
I’d like to thank @NedtheNerd also for this and agree it should be at the top of the forum, saved me a lot of grief.
I have now updated this guide following the release of Rasplex 1.6.0, the document on the first post has been replaced.
Regards
Thanks for updating.
Im not sure how to set my audio up properly my canton is stereo PCM but alot of my Films have HD audio i would rather keep that audio. I know it cannot pass through. But the volume sounds low. So i use volume amplification to turn the sound up i don’t really want to transcode to AC3 it doesn’t sound as good Ned could you help me with settings please how to set the audio for my Canton DM 55 soundbase please
Total hifi-dunce question from me - apologies in advance! I have very basic setup - OpenPHT on a Mac mini, hdmi to tv. That’s it. Since today’s update, I can no longer control volume with my Mac remote. Previously that only happened with x265 content, now it’s all content. Have played with the settings a little but to no avail, know next to nothing about audio. Previously just had output & passthrough devices set to default / hdmi, ac3 ticked, dts not ticked, I think. I’ve tried to follow your pdf, but I don’t have the options recommended available to me? Specifically, i now have 4 audio output device options
This is the Rasplex forum (Plex on a Raspberry Pi). You would have much better luck getting an answer on the OpenPHT or server forum.
