Dual Audio Out
Hi, is there any way to get the pi to audio out through the HDMI and a wolfson card?
I’d like to be able to send the audio to the hi-fi so I can easily improve the sound when needed.
Cheers,
Ray
I am also trying to do the same thing. I just bought a Wolfson Audio Card and don't have the knowledge to get it to work. It appears that a different kernel will need to be used to make it function. If you Click Here, Hiassoft, has created an OpenELEC patch with a kernel that has been compiled to work with the audio card. Unfortunately, I think the same would need to be done for Rasplex. If anyone wants to take on this job I'm sure the community would love to see this card supported.
