Dual Band USB options [?]
Has anyone had any luck with any dual band usb wifi adapters?
I'm using this one and so far so good (used exclusively on 5ghz)
https://www.modmypi.com/raspberry-pi-accessories/tenda-w522u-5ghz-wifi-dongle
What bitrates are you streaming at?
Nothing strenuous. Its mostly old DVDs and the like and, I would think, rarely gets above 2000 kbps.
Thanks. I'll try it out.
Bump!
Any word on this pngbanner? I would like to find a 5Ghz usb adapter that works OOB with rasplex, preferably off Amazon. 2.4Ghz is useless in apartments! Any more suggestions?
Personally it did not work very well for me. I decided to change the channel on my 2.4 GHz band instead.
