hi,
is this dongle supported on rasplex? it didn’t work for me (
Configuration tested:
0.6.0 on rpi2
0.5.1 on rpi2
0.6.0 on rpi1b+
hi,
0.6.0 on rpi2
0.5.1 on rpi2
0.6.0 on rpi1b+
Which adapter?
@rgritt said:
Which adapter?
This one https://www.raspberrypi.org/products/usb-wifi-dongle/
@dmbs said:
hi,
is this dongle supported on rasplex? it didn’t work for me (Configuration tested:
0.6.0 on rpi2
0.5.1 on rpi2
0.6.0 on rpi1b+
Don’t think so at the moment, the next release will use the 4.0.7 kernel, hopefully the drivers are there, but as none of us have one of these you’ll have to try it.
Regards
@NedtheNerd I probably could have done a google search to figure that one out haha
But you thought ‘What the Hell, I’ll troll a few sub forums’
Indeed it works fine with 0.7.0.
@dmbs said:
Can you mark this as ‘Answered’ then. Thanks.
