Wifi Dongle for pi2
I tested plex on a raspberry 2. Works great !
Witch is the best Wifi-Dongle for Streaming?
When possible 5ghz.
When possible 5ghz.
Edimax see here http://www.amazon.co.uk/Edimax-EW-7811UN-150Mbps-Wireless-Adapter/dp/B003MTTJOY%3Fpsc%3D1%26SubscriptionId%3DAKIAILSHYYTFIVPWUY6Q%26tag%3Dduc08-21%26linkCode%3Dxm2%26camp%3D2025%26creative%3D165953%26creativeASIN%3DB003MTTJOY
Monoprice --- secret of the pros
http://www.monoprice.com/Category?c_id=105&cp_id=10308
Both the tiny little one similar to the edimax one ned linked, and the big two antenna one work.
I'm using this because it supported 2.4Ghz and 5Ghz at 300Mbps
Requires a powered HUB though i've never tried it in the body of the Pi.
http://www.edimax.com/edimax/merchandise/merchandise_detail/data/edimax/global/wireless_adapters_ac600_dual-band/ew-7811utc/
works "out of the box" (WLAN AC+N, 2,4 + 5 Ghz, powered directly)
Thank you for your replay !
Just an FYI. I successfully used this adapter directly through the Pi 2, i.e. no hub required.
I have bought this model.
Playback FullHD (30 GB MKV) with dts and subbd subtitles works perfekt, without buffering or stuttering !
