Good day,
Hope you are all.doing great. Just wanted to find out does someone know how to.get the pleax app or plugin on a dune device?
Good day,
It’s not possible, unfortunately.
Plex app will run on Dune HD. I have one and installed the app from the Google Play Store
Hi Clive, thank you didi you install the Play Store on the Dune hd player?
The Dune devices technically run Android so it may be possible to sideload the Plex app on there. If you can install the Google Play Store or Amazon Appstore, you can install the app that way too. However, if your device doesn’t come with either of these stores natively, then your device is not technically supported so YMMV on how well it runs.
