Dune player
@Coyote: Try tu un- and reinstall. In the Program-configure section deselect using cache, should work now;-)
There is a small bug in the latest version - selection box in TV episodes is a bit off (shifted down), so it crosses episode title.
https://github.com/newloran2/emplexer/issues/40
In previous version everything was ok. I've tried to turn cache on/off - doesn't change anything.
Maybe there's something i can do to fix this?
Thank's to all for the beers  ;) .
Hi newloran2,
just give you a "Beer", go and have a Drink!
I allready know plexNMT, because i own a A-400 too. The A-400 is to buggy at the moment, you can Not really watch Movies without issues....
On new Dune Models Flash is very fast, i tried out the DFI from fet75 ( Dune Flash Interface). A dream will come True, if you Release a Flash emplexer Version. But yet now, your App is the best Plex client for Media players:-) BTW, DFI is very nice too, but NO PLEX CLIENT at all...;-(
Go on and thanks a lot!
BR
Peter
I heard it, the flash is much more integrated and faster in this new firmware that the new models are using.
There is other news that I think are coolest for those who make plugin for dune (must give it to count on the fingers :-)).
Things like plugin support javascript / html tend to make things easier and more beautiful :).
I like to the new native dev support (c/c++), with that api the developer has much more control over the system.
Sorry for this bug, the fix was submitted.
Thanks for a quick response! Now everything is in place.
Hi newloran2,
sounds very good :rolleyes:  A Flash-Version combined with the new Dunes Firmware would be awesome... Do you think, its worth to have a "new" or "next step" emplexer-Project?
Thanks a lot &
BR
Peter
Hi newloran2,
Thanks a lot &
BR
Peter
Peter911,
For that moment I would say that a flash version is not worth, despite the new firmware has greatly improved the integration and performace are not all models have that.
In my case I'm looking forward for the new version of firmwarer for smart models (I have a H1), that way I can better analyze and decide what the next direction of emplexer big :).
At the moment I think the current version is 0.1.
I'm starting to work on what will be version 0.2, will be completely rewritten to make it easier to add features (now with more experience will be easier)
In this new version I intend to make a big change in navigation and add some ideas that were appearing.
I imagine that a version 0.3 would use the new apis to make emplexer more like plex.
Do you have a link regarding the up & coming firmware for the Dune smart?
Nothing very concrete, just a comment on hdi facebook and something I read in the  plugins documentation.
On Facebook http://www.facebook.com/photo.php?fbid=569109966433645&set=a.173504802660832.43815.169066499771329&type=1&comment_id=2001209&offset=0&total_comments=38
Hi newloran2,
sounds great! Can`t wait... :rolleyes:
I really looking forward to 0.2. Good luck!
is there a setting on the Dune D1, to boot straight into emplexer?
@20mxm2:
no, this feature is only with the newer models available ( i use it with a Base 3D)
@20mxm2:
Hopefully it maybe possible, with the new firmware, newloran2 mentioned.
Thanks, now it works. But only video, about music it makes me see covers, but report me empty folders. Also "Channels" don't work, it loads all the selected channels, but the video streamings don't work.
Coyote74,
Music is not supported at this moment, will be in the new version.
About Channels, do you plz tell me what channel do you try to use?
For now some channels are not supported ( channels that use flash or silverlight ).
Coyote74,
Hi Newloran2,
I tried Apple Trailer and Trailer HD
I have some problems with the subs, on the webplayer(chrome) i got them, when i use the exemplerer (last master) no subs.
had switch between the options (cached and not cached), using nfs to play. playback is fine.
Seems when i restart the dune some subs work other don't...
Is anyone besides me trying to use emplexer to play video files from an internal disk drive within the Dune?  I have the Plex Media Server running on a MacBook Pro, and my movies are on a drive installed in a Dune HD Base 3D.  The emplexer client is able to gather and display the movie metadata from Plex, but none of those movies will actually play on the Dune -- I get a "format not supported" error.  The same movies play properly if I use the normal Dune interface, and they will also play via emplexer If I move the video files to the MacBook Pro.  But emplexer fails to play these files if they are on the Dune's internal drive.
I feel like I have not properly specified the path between these two machines, but I've tried many different variations in the emplexer NFS preferences.
I have tried reinstalling emplexer, restarting Plex, and rebooting all the hardware.  I'm using the latest beta firmware for the Dune.
Thanks in advance for any advice.
malinwa001,
This subtitles is external?
To enable subtitle on emplexer go to Setup->Playback->Subtitles->Enable subtitles by default for file. and enable it.
This is a terrible workaround while HDI don't enable subtitle config on vod playback.
wgoldman,
in your case you need to use smb insted nfs, becouse the dune don't have nfs server only client.
To do this, mount your dune hd on your mac and use this folder as source for your plex.
On emplexer go to setup -> connectionType and set to smb, on advaced smb configuration set the path to your dune ip.
This problably solve your problem.
Thanks, newloran2.  I followed your suggestions, and I even re-installed emplexer and restarted the Plex Media Server.  Unfortunately, the problem remains even though I switched to smb connection -- when I select a movie with emplexer, I get the same "format not supported" error.
