Dune player
...i just found a fifo.txt file in a dune plugin-log-folder, but its empty....?! No emploxer.log.
BR
Peter
BR
Peter
Ok, unplug your Dune, then follow steps 1,2 & 3 again.
BR
Peter
Petter911,
Restart your dune again and simulate your error, emplexer.log has created on same folder.
I'll leave it, in the capable hands of newloan2 !!! :D
Thanks, but i get no error Message, when Setting to nfs or smb. It only happens nothing, when i try to Start a film…
Thanks, but i get no error Message, when Setting to nfs or smb. It only happens nothing, when i try to Start a film...
send-me your emplexer.log :).
Hi newloran2,
thanks 20mxm2;-)
i tried everything. I reinstalled emplexer, but hfs or smb setting will not work. Maybe you can see something in the attached log-file? Will sent you a PM!
BR
Peter
Hi newloran2
My Synology DS412+ arrived today. Excellent kit  :D
I have plex installed on the DS412+ but i'm having problems configuring emplexer. when I enter smb or nfs, i get a message"smb/nfs advanced configuration".
Hi newloran2
I have plex installed on the DS412+ but i'm having problems configuring emplexer. when `I enter smb or nfs i get a message"smb/nfs advanced configuration.
:) I told to you, the Synology is a very good NAS (i'm very happy with my DS712+).
I'm confused, when you select nfs/smb the screen to configure nfs/smb path does not appear?
No parth appears
No parth appears
emplexer.log plz.
Hi newloran2
Have you seen my enhancement request on GitHub, is it possible?
SMB settings
https://github.com/newloran2/emplexer/issues/43
Hi newloran2
SMB settings
Hi 20mxm2, saw this issue, your sugestion is possible and i will implement :)
Hi newloran2,
i think, i found a bug: The resume function/ "On Deck" is not working for Bluray folder structures; do you know about this issue? :huh:
Any thoughts about path definition with smb/ nfs with my last emplexer.log? Thanks for any help! :rolleyes:
BR
Peter
Hi newloran2,
BR
Peter
Hi Petter,
I know about this issue, same thing happend with DVD ISO/BluRay iso, currently i don't have any manner to resume in this cases ( but i'm looking for a workaround ;)).
About your emplexer.log: I sent you  a pm with the probable solution.
Thanks! :rolleyes:
newloran, do you have an eta for default filter and earlier marked as watched?
Ktd Sorry for this delayed answer.
In this week and in the next i'll launch some versions with bug fixes and some back ports from 0.2 version.
Default filter, and mark  serie/seasons  as watched will commit soon.
For now i commited one new 0.1  version.
This version have many bugfixes to new firmware ( tv/3d models ).
Some non latin encode problens fixed.
Info screen now not show the path bar ( a litle more space ).
If your dune do not have system storage the cache always off.
More optimisations on banners load ( loading a bit faster ).
Now setup have an experimental option PlayBack Type:
In this option you chose if emplexer i'll use the current Vod Playback ( playback with summary and poster, but with some bugs and no subtitles chose/configure ) or Dune Playback ( default dune playback with all dune possibilities, but without poster and summary ).
Plz test and report to me any bugs :).
Hi newloran2
installs but can not configure/start. I will send you a log
