Dune player
Hi newloran2
installs but can not configure/start. I will send you a log
thanks 20mxm2, the problem is fixed, try again ;).
Thanks, emplexer is now working.
Hi newloran2,
great news, thanks for working on!
BR
Peter
Hello people,
I have a question to any one that use emplexer, do you think parental control in the client side useful?
i think there are other Features to implement first, or am i wrong?
Thanks for all the Great work!
BR
Peter
Hello people,
For the now I have added a "Kid Approved" category for movies, since some PG rated movies are okay for my children, but some are not. I also have 2 TV Show libraries, one for children and one for everyone else. It would be nice to be able to create different emplexer links on the home page that can address these libraries. It would be REALLY nice if you could also call up a library with specific filters (such as only certain categories). Also, being able to rename the "emplexer" label to something else would be helpful.
If none of that is possible, then having parental controls would at least prevent my children from watching things like "Prometheus", or "The Girl with the Dragon Tattoo". :o
I have to say, though, emplexer is awesome, and you have done a great job. Thank you for giving us the ability to use the Dune playback engine instead of VOD, because it instantly restored chapters in the mkv files, and subtitle control. I just hope when HDI switches to the Intel platform you don't lose your development tools.
While I'm talking about it, when I click info on a show, and then hit enter, I get "Error: Format not supported". But if I click enter when not on the info screen, it plays.
Is there a plan to incorporated the background artwork into the info screen?
BR
Peter
Yes Peter, there are most important features to be implemented first.
I asked here because two friends with younger children would love this feature.
Yes aiden, your case is very similar to that of my friends that I mentioned.
About the dune playback on emplexer: I have to make a lot of workaround for that to work and still have several bugs related to this, but I gradually improving this feature.
About the hdi products with intel: when that happens we will have better software like xbmc + plexXMBC (hippojay that does a great job), this time I believe the emplexer no longer needed :).
no, the Intel HDI Models are far, far away, so please go on to emplexer 0.2, ok?
Thanks a Lot!
BR
Peter
Thanks a Lot!
BR
Peter
Hi Peter911
I totally agree with you.
Hi Newloran2,
I need an help. I own a Dune HD Max, networked via LAN with other Digital Media Players and  with a Nas Synology DS212 + . The Nas has several shared folders on the network. Through your link, I have downloaded the file emplexer .zip. i have saved it on my I-Mac(I only clicked the file with the extension. Zip and after from a new page, I downloaded the file. I think with the extension. Zip. In fact the extension. Zip does not appear on my I-Mac and on the Dunes) after I have transferred the file, from the I-Mac to a shared folder placed on my Synology. I can see the file from Dune, but I can not install it. Why???? when I press the "enter" button on the remote control of Dune, the file opens and appear other text files. These files can not be installed on Dune. I just downloaded the. Zip file, but maybe I'm wrong something. The problem may be that I downloaded via my I-Mac?
Could you help me please?
Thank you.
Hi Newloran2,
Thank you.
<span>&nbsp;HI giandesy09</span>
Hi 20mxm2.
Thank you very much for your reply. I'm not a computer expert, I ask you to be patient with me and excuse me, please. I have downloaded the same  file you've posted. I just downloaded the file. ZIP, at least I think! I took this file from this topic. I just copied the file dune_plugin-emplexer.zip on a shared folder, placed on Synology and accessible by Dune. I clicked the "Enter button" of the Dune remote control (is it correct?). After clicking the enter button, appeared the same files that you posted, without file.zip, but no run started!!!!
You do not have to unzip the emplexer file. Only the .zip to an accessible Folder on your Nas. Then just Hit Enter with the Dune!
Hi 20mxm2.
Hello giandesy09,
To install any plugin on your Dune ( emplexer too ) you need to name your file with the prefix dune_plugin and this file need to have an extension .zip ( in lowercase ).
To install emplexer download from https://github.com/newloran2/emplexer/blob/master/dune_plugin_emplexer.zip?raw=true and rename (if needed ) like this dune_plugin_emplexer.zip.
Don't extract this file, only put this file in a place that dune have acess and press enter ( on remote ) in this file.
if you have any more problems (or the same :)) is just asking for help.
Many thanks to all you guys.
Well, I have to download the file. I've to put it into a shared folder, placed on the nas.  I have to rename it .zip and then I've to press the enter button. Right?
Yes,
After that this message will appear success_install.pnghttps://dl.dropbox.com/u/5493320/emplexe_plugins_screenshots/success_install.png .
After that emplexer will appear on applications section.
Fantastic...i will try, as soon as possible.
Thanks you very much.... :)
Hi newloran2,
sorry, but are there any news about emplexer 0.2 and a possible release?
Thank you very much!
BR
Peter
Hi newloran2,
BR
Peter
Hi Petter,
Unfortunately for now I do not have a date for the 0.2 release.
The development due to external factors is slower than I would like, but it's happening and sooner or later news may appear.
