I just tried it out on my MAX, but when i go into setup > applications i seet emplexer 2.0-b03, when i then try to connect to pms it says:
"System error, unhandled php plugin error. Call the php plugin vendor."
Any idea?
[1292] [t744112128] [2014-06-25 09:34:48.214398] ***** log_redirect_to_file() succeeded *****[1292] [t744112128] [2014-06-25 09:34:48.220942] [emplexer2] [server] preparing…
[1292] [t744112128] [2014-06-25 09:34:48.221153] [emplexer2] [server] reader fd: 7; writer fd: 10
[1292] [t744112128] [2014-06-25 09:34:48.221696] php engine: initializing…
[1292] [t744112128] [2014-06-25 09:34:49.675439] php engine: initialized.
[1292] [t744112128] [2014-06-25 09:34:49.675812] [emplexer2] [server] resetting include path to ‘.:/D/dune_plugins/emplexer2’…
[1292] [t744112128] [2014-06-25 09:34:49.688740] [emplexer2] [server] Ok.
[1292] [t744112128] [2014-06-25 09:34:49.689023] [emplexer2] [server] loading ‘firmware_ext/php/bootstrap.php’…
[1292] [t744112128] [2014-06-25 09:34:49.689209] [emplexer2] [server] executing “require (‘firmware_ext/php/bootstrap.php’);”…
[1292] [t744112128] [2014-06-25 09:34:49.710707] [emplexer2] [server] ‘firmware_ext/php/bootstrap.php’ loaded successfully.
[1292] [t744112128] [2014-06-25 09:34:49.710986] [emplexer2] [server] loading ‘firmware_ext/php/dune_api.php’…
[1292] [t744112128] [2014-06-25 09:34:49.711166] [emplexer2] [server] executing “require (‘firmware_ext/php/dune_api.php’);”…
[1292] [t744112128] [2014-06-25 09:34:49.734450] [emplexer2] [server] ‘firmware_ext/php/dune_api.php’ loaded successfully.
[1292] [t744112128] [2014-06-25 09:34:49.734799] [emplexer2] [server] loading ‘firmware_ext/php/dune_plugin.php’…
[1292] [t744112128] [2014-06-25 09:34:49.734982] [emplexer2] [server] executing “require (‘firmware_ext/php/dune_plugin.php’);”…
[1292] [t744112128] [2014-06-25 09:34:49.737228] [emplexer2] [server] ‘firmware_ext/php/dune_plugin.php’ loaded successfully.
[1292] [t744112128] [2014-06-25 09:34:49.737516] [emplexer2] [server] loading ‘firmware_ext/php/dune_plugin_fw.php’…
[1292] [t744112128] [2014-06-25 09:34:49.737771] [emplexer2] [server] executing “require (‘firmware_ext/php/dune_plugin_fw.php’);”…
[1292] [t744112128] [2014-06-25 09:34:49.742732] [emplexer2] [server] ‘firmware_ext/php/dune_plugin_fw.php’ loaded successfully.
[1292] [t744112128] [2014-06-25 09:34:49.743102] [emplexer2] [server] executing system properties cmd (number of properties: 6)…
[1292] [t744112128] [2014-06-25 09:34:49.743801] [emplexer2] [server] system properties initialized successfully.
[1292] [t744112128] [2014-06-25 09:34:49.744061] [emplexer2] [server] loading ‘/D/dune_plugins/emplexer2/main.php’…
[1292] [t744112128] [2014-06-25 09:34:49.744241] [emplexer2] [server] executing “require (’/D/dune_plugins/emplexer2/main.php’);”…
[1292] [t744112128] [2014-06-25 09:34:49.753508] php engine:[1292] [t744112128] [2014-06-25 09:34:49.777395] php engine:
[1292] [t744112128] [2014-06-25 09:34:49.827557] [emplexer2] [server] ‘/D/dune_plugins/emplexer2/main.php’ loaded successfully.
[1292] [t744112128] [2014-06-25 09:34:49.827897] [emplexer2] [server] ready.
[1292] [t744112128] [2014-06-25 09:34:49.828058] [emplexer2] [server] main loop started.
[1292] [t744112128] [2014-06-25 09:34:49.828896] php engine: DefaultDunePluginFw::call_plugin request :{“op_type_code”:“get_folder_view”,“op_id”:“1”,“input_data”:{“media_url”:“configRoot”},“plugin_cookies”:{}}
[1292] [t744112128] [2014-06-25 09:34:49.830028] php engine: this->availableScreens =
[1292] [t744112128] [2014-06-25 09:34:49.830448] php engine: Array
[configRoot] => EmplexerSetupScreen
[language] => LanguageChose
[mediaServer] => SetupMediaServer
)[1292] [t744112128] [2014-06-25 09:34:49.830834] php engine: Emplexer::get_folder_view MediaURL = configRoot
[1292] [t744112128] [2014-06-25 09:34:49.838256] php engine: Config::setPluginCookies
[1292] [t744112128] [2014-06-25 09:34:49.838828] php engine: stdClass Object
)[1292] [t744112128] [2014-06-25 09:34:49.839469] php engine: [/D/dune_plugins/emplexer2/classes/emplexer/utils/config.php:35] [E_NOTICE] Undefined property: stdClass::$plexPort
[1292] [t744112128] [2014-06-25 09:34:49.848672] php engine: error: selected language are not supported translation_en.json
[1292] [t744112128] [2014-06-25 09:34:49.859965] php engine: Error: DuneException caught: Erro: The emplexer is not configured, please, go to settings and add the ip and port.
[1292] [t744112128] [2014-06-25 09:34:49.863331] php engine: DefaultDunePluginFw::call_plugin response :stdClass Object
[has_data] =>
[plugin_cookies] => stdClass Object
)[is_error] => 1
[error_action] => stdClass Object
[handler_string_id] => show_dialog
[caption] =>
[data] => stdClass Object
[title] => Enter the ip and port for the plex media server
[defs] => Array
[0] => stdClass Object
[name] => plexIp
[title] => Plex Ip
[kind] => text_field
[specific_def] => stdClass Object
[initial_value] =>
[numeric] => 0
[password] => 0
[has_osk] => 0
[always_active] => 0
[width] => 500
[apply_action] =>
[confirm_action] =>
[1] => stdClass Object
[name] => plexPort
[title] => Plex Port
[initial_value] => 32400
[numeric] => 0
[password] => 0
[has_osk] => 0
[width] => 500
[apply_action] =>
[confirm_action] =>
[2] => stdClass Object
[name] => quickSavePlexPrefs
[title] =>
[kind] => button
[caption] => Save
[width] => 200
[push_action] => stdClass Object
[handler_string_id] => close_dialog_and_run
[caption] =>
[post_action] => stdClass Object
[handler_string_id] => plugin_handle_user_input
[params] =>
[close_by_return] =>
[preferred_width] => 0
)[params] =>
[1292] [t744112128] [2014-06-25 09:36:52.880180] php engine: DefaultDunePluginFw::call_plugin request :{“op_type_code”:“handle_user_input”,“op_id”:“2”,“input_data”:{“plexIp”:“62.133.214.4”,“plexPort”:“32400”,“selected_control_id”:“quickSavePlexPrefs”,“selected_media_url”:“configRoot”},“plugin_cookies”:{}}
[1292] [t744112128] [2014-06-25 09:36:52.881071] php engine: Emplexer::handle_user_input
[1292] [t744112128] [2014-06-25 09:36:52.881696] php engine: - print_backtrace at /D/dune_plugins/emplexer2/classes/emplexer/emplexer.php:129
[1292] [t744112128] [2014-06-25 09:36:52.882061] php engine: - handle_user_input at /tango3/firmware_ext/php/dune_plugin_fw.php:80
[1292] [t744112128] [2014-06-25 09:36:52.882436] php engine: - invoke_operation at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:84
[1292] [t744112128] [2014-06-25 09:36:52.882777] php engine: - call_plugin_impl at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:32
[1292] [t744112128] [2014-06-25 09:36:52.883097] php engine: - call_plugin at do_php_call:4
[1292] [t744112128] [2014-06-25 09:36:52.884035] php engine: Config::setPluginCookies
[1292] [t744112128] [2014-06-25 09:36:52.884608] php engine: stdClass Object
[plexIp] => 62.133.214.4
[plexPort] => 32400
)[1292] [t744112128] [2014-06-25 09:36:52.885972] php engine: DefaultDunePluginFw::call_plugin response :stdClass Object
[has_data] => 1
[plexPort] => 32400
)[is_error] =>
[error_action] =>
[data_type] => gui_action
[handler_string_id] => plugin_open_folder
[media_url] => configRoot
[caption] =>
[1292] [t744112128] [2014-06-25 09:36:53.208859] php engine: DefaultDunePluginFw::call_plugin request :{“op_type_code”:“get_folder_view”,“op_id”:“3”,“input_data”:{“media_url”:“configRoot”},“plugin_cookies”:{“plexIp”:“62.133.214.4”,“plexPort”:“32400”}}
[1292] [t744112128] [2014-06-25 09:36:53.209658] php engine: this->availableScreens =
[1292] [t744112128] [2014-06-25 09:36:53.210059] php engine: Array
)[1292] [t744112128] [2014-06-25 09:36:53.210398] php engine: Emplexer::get_folder_view MediaURL = configRoot
[1292] [t744112128] [2014-06-25 09:36:53.210777] php engine: Config::setPluginCookies
[1292] [t744112128] [2014-06-25 09:36:53.211126] php engine: stdClass Object
[plexPort] => 32400
)[1292] [t744112128] [2014-06-25 09:36:53.241437] php engine: valor de DEV
[1292] [t744112128] [2014-06-25 09:36:53.241802] php engine: Client::startEmplexerServerAndRegisterAsPlayer entrou
[1292] [t744112128] [2014-06-25 09:36:53.242092] php engine: Client::startEmplexerServer entrou
[1292] [t744112128] [2014-06-25 09:36:53.317124] php engine: Client::startEmplexerServer valor do pid
[1292] [t744112128] [2014-06-25 09:36:53.317610] php engine: Client::startEmplexerServerpid inválido registrando
[1292] [t744112128] [2014-06-25 09:36:53.317966] php engine: executando commando /D/dune_plugins/emplexer2/bin/lem-dune.bin /D/dune_plugins/emplexer2/bin/emplexer.lua > /dev/null &
lem: /D/dune_plugins/emplexer2/bin/emplexer.lua:28: module ‘inspect’ not found:
no field package.preload[‘inspect’]
no file ‘/D/dune_plugins/emplexer2/bin/dune/inspect.lua’
no file ‘/D/dune_plugins/emplexer2/bin/dune/lua/inspect.lua’
no file ‘/D/dune_plugins/emplexer2/bin/emplexer/inspect.lua’
no file ‘/D/dune_plugins/emplexer2/bin/dune/inspect.so’
no file ‘/D/dune_plugins/emplexer2/bin/dune/lua/inspect.so’
no file ‘/D/dune_plugins/emplexer2/bin/emplexer/inspect.so’
stack traceback:
[C]: in function ‘require’
/D/dune_plugins/emplexer2/bin/emplexer.lua:28: in main chunk
[1292] [t744112128] [2014-06-25 09:36:56.378743] php engine: Client::registerAsPlayer entrou
[1292] [t744112128] [2014-06-25 09:36:56.383042] php engine: Error: Exception caught: HTTP error: 0; CURL errno: 7 (couldn’t connect to host)
[1292] [t744112128] [2014-06-25 09:36:56.383639] php engine: - print_backtrace at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:102
[1292] [t744112128] [2014-06-25 09:36:56.384010] php engine: - call_plugin_impl at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:32
[1292] [t744112128] [2014-06-25 09:36:56.384331] php engine: - call_plugin at do_php_call:4
[1292] [t744112128] [2014-06-25 09:36:56.385774] php engine: DefaultDunePluginFw::call_plugin response :stdClass Object
[has_data] =>
[plexPort] => 32400
)[is_error] => 1
[handler_string_id] => plugin_show_error
[caption] =>
[fatal] => 1
[title] => System error
[msg_lines] => Array
[0] => Unhandled PHP plugin error.
[1] => Call the PHP plugin vendor.
[params] =>
[1292] [t744112128] [2014-06-25 09:37:52.087745] php engine: DefaultDunePluginFw::call_plugin request :{“op_type_code”:“get_folder_view”,“op_id”:“4”,“input_data”:{“media_url”:“configRoot”},“plugin_cookies”:{“plexIp”:“62.133.214.4”,“plexPort”:“32400”}}
[1292] [t744112128] [2014-06-25 09:37:52.088499] php engine: this->availableScreens =
[1292] [t744112128] [2014-06-25 09:37:52.089157] php engine: Array
)[1292] [t744112128] [2014-06-25 09:37:52.089463] php engine: Emplexer::get_folder_view MediaURL = configRoot
[1292] [t744112128] [2014-06-25 09:37:52.089883] php engine: Config::setPluginCookies
[1292] [t744112128] [2014-06-25 09:37:52.090250] php engine: stdClass Object
[plexPort] => 32400
)[1292] [t744112128] [2014-06-25 09:37:52.090768] php engine: valor de DEV
[1292] [t744112128] [2014-06-25 09:37:52.091092] php engine: Client::startEmplexerServerAndRegisterAsPlayer entrou
[1292] [t744112128] [2014-06-25 09:37:52.091381] php engine: Client::startEmplexerServer entrou
[1292] [t744112128] [2014-06-25 09:37:52.130931] php engine: Client::startEmplexerServer valor do pid
[1292] [t744112128] [2014-06-25 09:37:52.131341] php engine: Client::startEmplexerServerpid inválido registrando
[1292] [t744112128] [2014-06-25 09:37:52.131770] php engine: executando commando /D/dune_plugins/emplexer2/bin/lem-dune.bin /D/dune_plugins/emplexer2/bin/emplexer.lua > /dev/null &
stack traceback:
[1292] [t744112128] [2014-06-25 09:37:55.155880] php engine: Client::registerAsPlayer entrou
[1292] [t744112128] [2014-06-25 09:37:55.158945] php engine: Error: Exception caught: HTTP error: 0; CURL errno: 7 (couldn’t connect to host)
[1292] [t744112128] [2014-06-25 09:37:55.159477] php engine: - print_backtrace at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:102
[1292] [t744112128] [2014-06-25 09:37:55.159912] php engine: - call_plugin_impl at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:32
[1292] [t744112128] [2014-06-25 09:37:55.160473] php engine: - call_plugin at do_php_call:4
[1292] [t744112128] [2014-06-25 09:37:55.161908] php engine: DefaultDunePluginFw::call_plugin response :stdClass Object
[has_data] =>
[plexPort] => 32400
)[is_error] => 1
[caption] =>
[fatal] => 1
[params] =>
[1292] [t744112128] [2014-06-25 09:38:28.334293] php engine: DefaultDunePluginFw::call_plugin request :{“op_type_code”:“get_folder_view”,“op_id”:“5”,“input_data”:{“media_url”:“main”},“plugin_cookies”:{“plexIp”:“62.133.214.4”,“plexPort”:“32400”}}
[1292] [t744112128] [2014-06-25 09:38:28.335139] php engine: this->availableScreens =
[1292] [t744112128] [2014-06-25 09:38:28.335540] php engine: Array
)[1292] [t744112128] [2014-06-25 09:38:28.335853] php engine: Emplexer::get_folder_view MediaURL = main
[1292] [t744112128] [2014-06-25 09:38:28.336312] php engine: Config::setPluginCookies
[1292] [t744112128] [2014-06-25 09:38:28.336671] php engine: stdClass Object
[plexPort] => 32400
)[1292] [t744112128] [2014-06-25 09:38:28.337191] php engine: valor de DEV
[1292] [t744112128] [2014-06-25 09:38:28.337504] php engine: Client::startEmplexerServerAndRegisterAsPlayer entrou
[1292] [t744112128] [2014-06-25 09:38:28.337788] php engine: Client::startEmplexerServer entrou
[1292] [t744112128] [2014-06-25 09:38:28.371213] php engine: Client::startEmplexerServer valor do pid
[1292] [t744112128] [2014-06-25 09:38:28.371597] php engine: Client::startEmplexerServerpid inválido registrando
[1292] [t744112128] [2014-06-25 09:38:28.371985] php engine: executando commando /D/dune_plugins/emplexer2/bin/lem-dune.bin /D/dune_plugins/emplexer2/bin/emplexer.lua > /dev/null &
stack traceback:
[1292] [t744112128] [2014-06-25 09:38:31.400098] php engine: Client::registerAsPlayer entrou
[1292] [t744112128] [2014-06-25 09:38:31.402815] php engine: Error: Exception caught: HTTP error: 0; CURL errno: 7 (couldn’t connect to host)
[1292] [t744112128] [2014-06-25 09:38:31.403420] php engine: - print_backtrace at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:102
[1292] [t744112128] [2014-06-25 09:38:31.403776] php engine: - call_plugin_impl at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:32
[1292] [t744112128] [2014-06-25 09:38:31.404192] php engine: - call_plugin at do_php_call:4
[1292] [t744112128] [2014-06-25 09:38:31.405525] php engine: DefaultDunePluginFw::call_plugin response :stdClass Object
[has_data] =>
[plexPort] => 32400
)[is_error] => 1
[caption] =>
[fatal] => 1
[params] =>
[1292] [t744112128] [2014-06-25 09:44:01.708965] php engine: DefaultDunePluginFw::call_plugin request :{“op_type_code”:“get_folder_view”,“op_id”:“6”,“input_data”:{“media_url”:“main”},“plugin_cookies”:{“plexIp”:“62.133.214.4”,“plexPort”:“32400”}}
[1292] [t744112128] [2014-06-25 09:44:01.709750] php engine: this->availableScreens =
[1292] [t744112128] [2014-06-25 09:44:01.710237] php engine: Array
)[1292] [t744112128] [2014-06-25 09:44:01.710529] php engine: Emplexer::get_folder_view MediaURL = main
[1292] [t744112128] [2014-06-25 09:44:01.710892] php engine: Config::setPluginCookies
[1292] [t744112128] [2014-06-25 09:44:01.711315] php engine: stdClass Object
[plexPort] => 32400
)[1292] [t744112128] [2014-06-25 09:44:01.711782] php engine: valor de DEV
[1292] [t744112128] [2014-06-25 09:44:01.712165] php engine: Client::startEmplexerServerAndRegisterAsPlayer entrou
[1292] [t744112128] [2014-06-25 09:44:01.712462] php engine: Client::startEmplexerServer entrou
[1292] [t744112128] [2014-06-25 09:44:01.748040] php engine: Client::startEmplexerServer valor do pid
[1292] [t744112128] [2014-06-25 09:44:01.748457] php engine: Client::startEmplexerServerpid inválido registrando
[1292] [t744112128] [2014-06-25 09:44:01.748815] php engine: executando commando /D/dune_plugins/emplexer2/bin/lem-dune.bin /D/dune_plugins/emplexer2/bin/emplexer.lua > /dev/null &
stack traceback:
[1292] [t744112128] [2014-06-25 09:44:04.773078] php engine: Client::registerAsPlayer entrou
[1292] [t744112128] [2014-06-25 09:44:04.775842] php engine: Error: Exception caught: HTTP error: 0; CURL errno: 7 (couldn’t connect to host)
[1292] [t744112128] [2014-06-25 09:44:04.776444] php engine: - print_backtrace at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:102
[1292] [t744112128] [2014-06-25 09:44:04.776797] php engine: - call_plugin_impl at /D/dune_plugins/emplexer2/lib/default_dune_plugin_fw.php:32
[1292] [t744112128] [2014-06-25 09:44:04.777188] php engine: - call_plugin at do_php_call:4
[1292] [t744112128] [2014-06-25 09:44:04.778502] php engine: DefaultDunePluginFw::call_plugin response :stdClass Object
[has_data] =>
[plexPort] => 32400
)[is_error] => 1
[caption] =>
[fatal] => 1
[params] =>
