Dune player
this plugin looked interesting so I tried to install it. from what I have read the new version 2 does not support SMB so I tried to install version 1. it seems to install ok but when I launch it I get the error (impossible to launch application)
I tried this on both my players (zappiti minis) which are basically dune tv303d's. the firmware is the latest zappiti firmware
(140430_0849_b8)
after that I decided to try version 2, that installed no problem and I was able to configure my plex ip. seems to work ok. I see movie wall and it plays video fine (would still prefer smb) but anyway I do not see any way to view movie synopsis.  it shows movie posters and it plays the movie if I hit ok or play but I don't see any way to view movie details. am I missing something is there anyway to view movie details in version 2 of emplexer?
or if not does anyone know if this will be added in a future version, also does anyone know the status of version 2 is smb version coming out soon or has development stopped for this dune plugin?
thanks for any info you can provide.
Michael
@weyb:
Do you have the authentification in your local Network enabled in PLEX? Exempler cannot handle this, so you have to disable it!
Regards!
Mike
hello Mike !
i'm not sure to know where to look !
is it in PLEX ?
all i could find in PLEX "network" parameters related to my LAN is :
"list of networks authorized without authentication :
192.168.0.1/255.255.255.0"
is it what you were thinking about ?
an other parameter seen in "connection" (translated from french) :
"force authentification on local network
set authorized networks to 127.0.0.1/255.255.255.255. It forces others PCs on the LAN to authenticate in order to access the server."
--> it is not enabled
kind regards
Still looking for some help on the PHP error with v2 (see my last post).
Ratmice its a general error. No solution available. Newloran2 is working on it. I hope :-?
I was just hoping that the error log may give some clues as to why, and possible fixes.
@weyb:
Yet, that´s what i mean, but when the authentification on the local Network is disabled you must have another Problem, on my Dune TV-303D the build works perfect.
Kind Regards!
Mike
Hello people and sorry for my very long absence,
I think in fill days i'll be able to go back to emplexer development.
If any one have some problems with v2 (like that unhadle php error) try to use the release version  https://github.com/newloran2/emplexer/releases if the problem remain please send-me your emplexer2.log.
Thank's to all.
 OK, nevermind, got it installed.
the use of "zip -r dune_plugin_emplexer2.zip *" while in the folder containing the Emplexer 2.0 files makes a proper plugin that the Dune plugin manager can install.
Now on to figuring out the "unhandled PHP plugin error" that's coming up  :( The spoiler below contains my Emplexer2 log. Any help would be appreciated.
the only thing that looks like an error is this, and I have no idea what it means   :wacko:
lem: error loading module ‘lem.utils’ from file ‘/persistfs/plugins/emplexer2/bin/mac/lem/utils.so’:
/persistfs/plugins/emplexer2/bin/mac/lem/utils.so: ELF file version does not match current one
ratmice use the release version https://github.com/newloran2/emplexer/releases
hello,
i discovered an emplexer2-b03 release on https://github.com/newloran2/emplexer/releases after looking for my error message on internet.
So I installed it on my Dune.
it worked fine, I had to enter my NAS @IP, full of hope, but when I launched emplexer2-b03, it says also "unhandled PHP plugin error"
thank you verym uch in advance for your help !
regards
weyb,
Please send-me your emplexer2.log.
No help for these PHP errors? Really would like to try v2.
Also, what would cause the watched status to not update, when no setting have been changed. Both my Dune's are not updating now, and also do not resume partially watched content.
About the v2 the release version work's.
About the status update, the v1 have a bug, im same cases the emplexer stop to update the status on pms, i fixed that bug on v2.
@weyb:
Regards!
Mike
Yes for now this is a problem, to solve, im pms go to setup -> connect -> show advanced and uncheck "Require authentication on local networks".
(140430_0849_b8)
Michael
Michael,
The development of emplexer is not stopped only paused due other things that demand my attention.
If not goes wrong in some days i will able to go back to emplexer development.
About the info screen i added a issue on git hub https://github.com/newloran2/emplexer/issues/89.
About the smb i'll add smb and nfs in the next releases.
The v2 for now is not production ready, i just release him to people make some tests, i strongly recommend you to use the emplexer v1, these version have some problems, but have more features and is much more stable.
Is possible to install emplexer v1 and v2 in same dune unit.
It nice to see you back here again and that you still wants to work on emplexer.
Looking forward to the next release.
Just got reply on my question about emplexer's support of "seek" functionality so I have option to go to time where I stopped previous time: "For now resume and seek with plex client are not supported. I'll add this feature in next releases."
<span><a  class="" href="https://forums.plex.tv/user/72494-newloran2/" title="">newloran2</a></span>
I wish you have time to add this feature soon:) This will allow me (and other's, probably) to use Dune more frequently as Plex player.
newloran2
Have you tried v1? Both resume and skipping works in v1.
What is best Dune box to use currently as Plex Player and compatible with your player module ? with Ethernet please ;)
I use two dunes at home, one 303d and one smart h1 both work very well.
To buy I recommend one 3d model.
But if you can, go to hdi site http://dune-hd.com/eng and compare some models.
Enviado do meu iPhone usando o Tapatalk
weyb,
Hi Newloran2 !
it's a relief to hear about you & to hear you'll workk on emplexer again !
because I'm stuck with v1 and with v2...
@everybody
where can I find the emplexer.logs please ???
I assume they're on my Dune - but where ? and how ? I never went on the Dune to look at files & directories...
thank you very much for your help
kind regards
weyb
Just come across , it is great !
I’m struggling to get the remote play from an iOS device working. If you need anything else let me know.
Hi Newloran2,
its good to hear you will continue to work on this. I am excited about it. however you mentioned in your reply to me to use version 1 for smb, however I have tried to install and use version 1 on both of my media players (zappiti mini) which is basically a dune tv303d but as I mentioned in my original post it does not work. I cannot get it to launch. I get the same error on both of my media players (impossible to launch application)  I cant configure plex ip it just doesn't launch. any idea why or how to fix and get it working? as I mentioned I don't have this problem with version 2
thanks again
Mike
actually just found the solution a page or 2 back in this thread... version 1 works great, looking forward to smb and movie info in version 2. thanks for this app, it works really well
hi Mike
How did you get version 1 to run, I download it and it isn't a zip file, so it doesn't want to work. I tried renaming to .zip and that didn't get me anywhere, but I am using a Mac .
Cheers
Nathan
Newloran,
I was able to get the release v2 to load and start. A Few issues:
1.Is there a way to change the view in this version. At the season level I get episode thumbnails, but with no episode title. I can't tell if my problem with the watched/unwatched status is actually working without seeing the titles.
2. the pop-up menu button does not seem to be working no matter what level I am on. Correction, it does get me to the menu while watching an episode, but nowhere else.
3. pressing the info button now gives the dune style info box and a filename box at the to of the screen. However the filename is not very informative as it has the form "http://10.0.1.5:32400/library/parts/40054/file.mkv" rather that the actual file name. Any way to change this?
4. hitting the popup menu button when viewing the episodes within a season causes the dune to restart.
I like the fact that it now has a banner view to choose TV series.
Also, after I installed the new release version 2b03, the resume function  is working again on v1 ?!? Not sure what's going on there. **Correction, this worked exactly once and then back to not resuming.
hi everybody,
where can I find the emplexer.log please (v1 and v2, as i have both) ???
I went on the Dune to look at files & directories (via PC/network/Dune), but couldn't find nothing...
kind regards
weyb
I've tried to run v1, however, as few other people I couldn't do it due to some generic PHP error.
I'll try again anyway. Thanks!
Hi Newloran2 !
@everybody
kind regards
weyb
weyb,
To get the emplexer.log attach to your dune one usb drive or internal hdd.
In the root of that hdd make a folder named dune_plugin_logs, after that restart your dune and use normally your dune.
The emplexer.log appear /dune_plugin_logs/emplexer.log
hi Mike
Cheers
Nathan
Use that link https://github.com/newloran2/emplexer/blob/master/dune_plugin_emplexer.zip?raw=true  and don't extract it. the safari usually extract it.
Newloran,
rat mice thanks for your report,
1) Change view is in my todo.
2) pop-up button for now have no use on employer 2, maybe i add some functionality to it in one future release.
3) Today emplexer aways show the file path i opened a issue to fix it https://github.com/newloran2/emplexer/issues/90 .
4) Can you please open an issue on github with your log after this restart?
Fell free to suggest any thing you like to see on emplexer.
