Hello,
dune303D+emplexerV1 and NASNetgear+plex (Version 0.9.11.4.739-a4e710f), how through emplexer watch movies with the expansion of DVD and ISO?
My setup:
1 Dune HD Smart H1 always with last stable version (140610_0131_b8 now).
1 Dune 303d always with the last beta firmware (140827_0132_b9 now).
In bowth of then v1 and v2 works very well ;).
Hello,
Hello Grat75,
Emplexer V1 have full support to Bluray/DVD ISO/folder but a while since the Plex Media server dropped support for these kind of files, if you test with check in web interface you see that files are not listed.
If you like to use PMS with these files i recomend you remux then to MKV (i recomend the make MKV).
There is a problem,
If the plex (NASNetgear) change (update) the cover (fanart) in emplexerV1 (dune303D) cover is not updated, Dune shows the old cover.
There is a problem,
Yes this is a bug on v1, the emplexer never renew the image cache, this bug fixed in v2.
Enviado do meu iPhone usando o Tapatalk
hello newloran2,
do you think you'll have time this month (like you said earlier) to look at the php problem in v2 that some of us have ?
regards
hello newloran2,
regards
Yes, i will back at the end of this month (after the xmas) and i will work hard to turn the emplexer v2 a valid replacement to v1.
hi
great news !!!!!!!!!!!
so have a happy Xmas !
regards
I seem to have broken it.....
Both my v1 and v2 emplexers will not start. I also had issues with my roku not seeing the server (again previously working fine) untillI put a pin number in for it to connect.
I think (maybe?) this is something to do with the multiple user accounts that have recently been implemented. Any tips please?
Hello,
I am completly new to plex and of course to this really nice plugin.
I hope I did not miss anything in this quite long thread.
I just installed both emplexer versions to my Dune BD Prime 3.0.
Am I right that the V1 cannot be used as a remote player from an other device?
With V2 I can see the emplexer in the player list, but when I try to connect, I get a time out message at my Windows Phone and Win8.1 App. Does anybody else have the same issue and got it probably solved?
Let me close my reply with a big thank you to newloran2, great work so far. It makes the Dune device so much more usable in a modern way / net.
Seems it does work, it was upnp disabled in the latest server update that was causing the issue.
Hello,
I'm unable to use this plugin. I get an "Unhandled PHP plugin error." I'm using the lastest version found here: github.com/newloran2/emplexer/releases
I have a Dune D1 with the latest firmware, my PMS is running on a Synology NAS. I have reseted my Dune settings twice and I have reformated my internal drive and USB stick. Nothing works...
Any tips for me?
Thanks for your time.
That's the best Christmas present many of us could get! Thanks for all your work on this.
Made a donation so you can order pizza while working late. :)
Feliz Ano Novo!
Happy new year, all!
Any news?
Happy New Year!
Any plan to support the Plex Home Feature?
Happy new year to all.
Hello,
Any tips for me?
lpr,
The emplexer v2 for now is much unstable i recommend you to use the V1.
Feliz Ano Novo!
Happy new year raysundstrom thanks for your help :).
Any news?
Hello shotfirer,
yes, I'm working on all the functionality needed to replace v1.
Happy New Year!
Yes, i opened an issue for that https://github.com/newloran2/emplexer/issues/93 .
But first things first, i need to implement the most of v1 features first.
I think in a few days i will have a new beta v2.
Lovely! Looking forward to try the next release.
hi
as requested by newloran2 some time ago, here are my wishes as functionalities (for music) for emplexer v2 :
- ability to display the lyrics, the different covers, year, etc. when available
- random play on a selection (album or artist)
- view per year - and decade (aahh, the 80's...)
[EDIT] - possibility to go directly to the artists or albums beginning with a specific letter (ex : "T"), to avoid to scroll endlessly all the artists or albums before finding what you want...
(EDIT] - possibility to sort/choose the songs via their note
about the movies :
- management of the seen/not seen movies
- indication of the available audio languages & also for the subtitles
and of course, best wishes for emplexer for 2015 !!!!!!!!!
regards
I seem to be unable to start emplexer version 1 on a Zappiti 303D. After I install the application, the interface asks we whether I want to launch the application. If I say yes, I get a prompt "impossible to launch application". I am using a USB stick of 1 GB as system storage. The player is running on firmware version 140430_0849_b8.
Any ideas? Thanks you so much advance!
SOLVED!
I thought emplexer required a USB stick as system storage. Instead, it requires that there is internal storage (USB or SATA) available that is not _not_ initialized as system storage :-)
Does it make any difference whether in addition to standard storage there is any system storage available?
First of all, THANK YOU SO MUCH FOR THIS WONDERFUL PIECE OF SOFTWARE! I have been so fed up with the Zappiti interface. And now, I am happy!
After the praise come the questions :-)
Is there a an explanation/documentation of the options that are available in the setup? The ones that interest me the most are listed below. Perhaps someone aould like to copy / paste and comment?
Connection Type
What are advantages/disadvatages of each? Is there a recommended option?
HTTP:
NFS:
SMB:
Use Cache
Is there a recommended value?
Playback Type
What are advantages/disadvatnages of each? Is there a recommended option?
VOD:
Dune:
Hello,
in emplexer on Dune include startup of the selected folder, for example Multfilms?
How to add your fanart, instead of a black background?
P.S.Emplexer very necessary for my daughter :) .
