Dune player
Even though it lists the shares it sees, it doesn't actually save the path. You will see if you go in to edit, the path is empty. Just put them in and it works.
Ex) Dune shows /Movies as a share on my server. Same error if I just try and play a movie right away. Instead I go in and edit and add /Movies as the path and presto! now it works. :)
Sorry I didn't understand. Is it ok now or still problem?
Mine works fine now!
mine works fine too. Just trying to explain to others
Sounds good! :)
Багов с ремуксами, рипами и DVD не заметил.
Просьба, по возможности добавьте пожалуйста в "Виде" при котором заполнен обложками весь экран, строку в его нижней части с названием фильма при перемещении по обложкам.
Hooray ! it works finally !!!!!!!!!
thanx to interweb-tech !
I still have 2 points :
- when i click on "all movies", I have the posters of the movie in "landscape" format... beurk... (if I click on the "A" button on my Dune remote, i have the list of the names of all movies on the left, + the poster in correct format on the right  - pressing "A" again give me all the posters in landscape format),
- I'd like to be able to have the summary of the movie (with the year, the rating, the actors, etc) when I click on it, and when I click again, the movie starts
would it be possible ?
kind regards !!!!!!!!!!!!!!
VERY NICE JOB !!!!
Т.е. названия к обложкам? не очень понимаю "строку в его нижней части". А как на счет пропадания IP ?
VERY NICE JOB !!!!
congratulation! But I confused your "landscape" format. For me looks like you use "home video" library type instead "movie". Is it true?
About summary, yes it's possible, I'll add  possibilities make  this settings in setup screen in next update
VERY NICE JOB !!!!
When viewing the wall of posters, move to one and click the INFO button on remote. That will show details about the movie.
But if "info" screen won't appeared it further confirms my guess you are using wrong library type
Doesn't seem to work for me?
It's pre-populated with the network shares, but they're drive letters, but it won't let me change them? I've tried 'Pop-up', 'Clear', 'Enter' and almost every other button. Where am I going wrong to be able to change the path?
Will be great to have a nice 'Plex' solution, so keep up the great work! :D
jmper, have you had anymore time to look at syncing time line, watched and unwatched?
Да, названия к обложкам, сами названия можно разместить в нижней строке, т.е. рядом с "красной кнопкой А".
Баг с ip не проявился на обеих дюнах, при том, что одна из них стояла в режиме ожидания, а вторая была отключена и включена, обе сконектились с NAS по NFS без проблем.
Sorry, I can't understand "but they're drive letters" on dune. what do you mean?
I'm working on it. It's favourite task now. As a quick solution I can make update with possibilities mark  watched/unwatched manually, by pressing the button on remount control
Not sure if this was for me, but think it was.
I mean it show's "M:\Movies", "T:\TV" etc rather than smb: or nfs:
Does that make sense?
you should make shared your T:\TV and etc. as smb (or nfs) as smb://TV or something else. Which server platform do you use? (I guess windows)
sorry, it's too late for me now. Continue tomorrow. have a good night!
Ah ha, am I supposed to make the changes within Plex, rather than on the Dune?
Indeed, it's Windows.
