Yes, you should setup connections. something like this: If you have folder K:\media\movies on plex server and folder \movies\ shared as "my_movies", you should set you connection like smb//(or nfs) \my_movies
And I should make those setting changes where?
If it's on the Dune, within "Setup/Applications/DPC Setup/Connections", it won't let me change the settings. It highlights the box/field, but won't let me select it and change it.
If it's not there, where do I make the changes?
I feel I'm missing something here, as I seem to be the only person with the problem? :wacko:
Of course on dune. after "Setup/Applications/DPC Setup/Connections" just press the enter on remote control on selected connection
This is the problem, I am pressing enter (and many other buttons), but it won't do anything other than highlight the path. It won't let me change it...?
Just to add, I'm using b1_02
what is it b1_02?
what is it b1_02?
That's the version of DPC I'm using, as that appears to be the latest one on your site? Is that not correct?
Oops, sorry :) of course It's correct.
Do you setup SMB or NFS share on server? If you can't press connection buttons means same internal error appear. Could you send me log file?
hi jmper,
the movie I watched today with DPC does not appear as "watched" on PMS...
:blink:
I saw this : https://www.reddit.com/r/PleX/comments/2xwf8y/when_does_plex_mark_something_as_watched/, so as I watched until the credits, it should be ok
is it ok with everybody else ???
regards
Its already been mentioned in this thread that watched/unwatched isn’t supported yet.
jmper is working on supporting that and it’s high priority.
sorry ! sorry ! sorry !
hi jmper,
would it be a good idea if you gave the list of bugs & functionalities you are working on now ?
so it would prevent people (like me...) to tell you about problems or suggestions already taken care of, no ?
:rolleyes:
regards
Hello all
Yes, it's good idea.
My task list by priority:
1) make Plex server notification
1a watched/unwatched
1b register dpc as player and notified how long time watched
2 make possible play all albums of artist / shuffle play list
3 design improvement ( add screen without left part but with captions of movie/serials )
- remove additional series name on unwatched list
- maybe something else
bugs:
avoid crash with windows based plex server
avoid crash with some series filters
any proposal?
hi
it's already a lot to do !
I can add as suggestions :
- show the fanart (in the background ?) when you click on "info" to have the summary of the movie
- developp the "info" window (with the summary, etc) in such a way (specific config file ?) so other people (like me) can customize it (I'd like for example to reduce the size of the letters)
kind regards !
hi
I can add :
kind regards !
add fanart is possible but customize info screen, I'm afraid, not.
Hi; thanks jmper for DPC
thanks weyb for install guide
I have a problem with covers and i’m not sure what i have to config to succes.
i have configured on my nas syno ds214play SMB and no problem to explore folders and play movies or tv shows with DPC.
My shared folders on nas are
On PMS volume1/videos for movies volume1/Series for Tv Shows and volume1/video/Docu for Home videos
i set up folders like this and it’s possible to navigate and play shows
PMS on my nas exemple for TV shows
PMS /library/sections/
I try to config in DPC setup folder like “smb://diskstation/Series” (nothing work 'can’t read);
With config where i name folder “Series” no problem for play tv shows and navigate but impossible to see pms tv shows covers.
I don’t know where is my configuration problem, nas or PMS.
If someone can help me to config.
Best regards boby.
Hello. Could you show server answer on request your_ip:32400/library/sections/1/all ?
I see IP address 192.168.1.1x on your picture. Is it your real settings or it just for hide your real ip on this picture?
i just hide on the picture ;)
Ok. Do you use the "system storage" on your dune?
