Dune player
nop on my dune 303d i don't put system storage (usb key on the back ?)
I think it's a reason. Try to install system storage. Any usb drive >2Gb
Perfect jmper :)
i put an usb key for systeme storage and all it's fine now :)
Big Thanks without you i would have never found the solution :)
jmper i don't remember if you will work for show episode number on DPC like we see on PMS ?
DPC
PMS
Welcome!
Try press "red" button on your remote control for select suitable view. Or you mean label "Episode n"?
I mean label "Episode number"
Hello,
I don't know why, but just I can connect to my Plex server with this plugin. I get a "Plex server address http://192.168.1.myip:32400 does not respond". I have a Dune HD Smart D1.  Am I missing something? All my other clients can connect to my PMS. Thanks.
Hello,
Hello!
Could you send me log file?
Jmper
Добавьте пожалуйста меню - возможность выбора воспроизведения видео с начала или с места остановки.
Please add the menu - the ability to select a video from the beginning or from their seats Stop .
Hello Jmper,
first i want to say: thank you very much - this is beautiful work and for a first run absolutely perfect!
i just sent you a small donation, as your efforts take the dune-experience in my opinion to a completely new level …
please feel free to contact me if you need german localization, i would be proud to help out there.
for improvements and ideas: maybe you could show in the filters list to each category the sum of found elements [in brackets], also in
the dune bar where you show the path to the selection …
thanks again and keep up the good work!
Jmper
Yes. I'm working on it too
Hello Jmper,
Thank you very much! It's very kind of you :)
Good idea. About to add count of elements to each filter it need to check because performance, but it more safety to add this info to path bar.
- "playlist is empty" message when i click on a movie
same for me here... what could  be the error?
Probably something wrong in your connection settings
hi,
i tried to describe as precisely as possible how to configure the connection settings p49
regards
Update.
  • Avoid crash and improved work some TV-show filters.
  • Changed TV-show names in case filters "unwatched" and etc. - thanks ktd
  • Avoid crash and improved work with windows-based Plex servers. Now it's possible use windows servers
download https://dl.dropboxusercontent.com/u/8488718/dune_plugin_dpc_b1_03.zip
I know you wait watched/unwatched marking function. I'm still working on it and I hope release it very soon
Just installed the new version and I can now edit the connections, which is great news! As a result, it's working for me!
However, one minor issue - I'm not getting any artwork / cover art?
Any ideas?
Thanks and keep up the great work!
Any ideas?
I guess you don't use "system" storage. If it true you should install it
Ah ha, all sorted, thanks for the pointer!
Now working great!
Big thumbs up and looking forward to continued use as it's further developed!
Hello,
I get this message even in the settings on my Dune HD so I just unable to setup the plugin. It is impossible to change neither server IP nor server port because of this message. Both webclient and Windows 8.1 client works like a charm.
Hello!
where should I get this log file?
