The TV show are out of order like Castle Macgyver and others use Tvdb the shows are in order when I use Roku and Plex on the computer but not on dune?
Red button is indeed the solution to get a wall of cover art.
When you click INFO for a movie and then start playing with the button on bottom left, movie starts. When you select INFO for another movie and start it with the same button on bottom left…it starts the previous started movie again?? So happens at every Dune Startup (from off yo on)
Greetings
update (v1_07)
Fixed many bugs.
Now is possible login on dune (you may use PlexPass), but it still works only inside local network
Added Channels function. It VERY experimental. Not all channels work. In next updates i’ll use dune codecs, hope it will get more working channels.
dl.dropboxusercontent.com/u/8488718/dune_plugin_dpc_v1_07.zip
Thanks Jumper for 1_07.
I will install on my dune when i comeback home
Welcome back jmper!
Hope you’ll have a chance to look at my log file I sent via PM.
@phatboyc said:
Welcome back jmper!Hope you’ll have a chance to look at my log file I sent via PM.
Hello! just try new version. Hope it will solve your issue
Hai jmper!, great
Now it works. Thank you.
P.S. I had to select the list of artists WITHOUT photos because of locking. I’m prompted with “out of time” (translated in italian…). Overtime it locks I had to reinstall the player otherwise it doesn’t run anymore.
Wow wow wow it works and its beautiful!
Like you said channels is a hit and miss for me but probably because the one I am mostly interested is not an official channel.
Thanks again!
Thanks again for the great work on this plugin.
Would it be possible to have the plugin send resume information to the server, so that if we start a film from DPC it sends the info where it stops and it goes to “on deck” on the server to have the option to resume from another player?
x2 for above request.
In similar line. Would it be possible when DPC says “connecting” to plex media server it always sends a wake on lan magic packet? Since Dune doesn’t require any transcode from PMS my computer with PMS is sleeping by the time the movie ends. Would be helpful also when first launching DPC since sometime I forget to wake up my PMS computer.
So basically send a magic packet every time DPC connects to PMS.
Hello jmpr, would it be possible to have dynamic playlist like in normal Dune operations. Press SELECT over desired titles and then PLAY to start the Playlist.
Thank you.
P.S. Any news about my problems in having the list of starring actors with photos (thousands and thousands of entries)?
@phatboyc said:
x2 for above request.In similar line. Would it be possible when DPC says “connecting” to plex media server it always sends a wake on lan magic packet? Since Dune doesn’t require any transcode from PMS my computer with PMS is sleeping by the time the movie ends. Would be helpful also when first launching DPC since sometime I forget to wake up my PMS computer.
Maybe this could help if you are running your server on Windows.
Great work on 1.07. The PlexPass integration works great with the Trakt plugin.
Have you had any chance to look at adding season and episode number into the info?
@ktd said:
jmper, could you please add a bit more episode info in the next update?
If you look at the attached pic you can see emplexar at the top and doc at the bottom.
I would like to see season and episode number and a bit of the summery.
@lpr said:
Thanks again for the great work on this plugin.Would it be possible to have the plugin send resume information to the server, so that if we start a film from DPC it sends the info where it stops and it goes to “on deck” on the server to have the option to resume from another player?
Hello @lpr It already can send info for server about playing/pause/stop movie/serie and timeline. Now I found bug with sending info about “already seen” command. And of course info appears onDesk. Isn’t it?
Hello @phatboyc Great Idea, I’ll try!
Thank you.P.S. Any news about my problems in having the list of starring actors with photos (thousands and thousands of entries)?
Ok. I plan this function for music libraries, but why not for movies ![]()
@ktd said:
Great work on 1.07. The PlexPass integration works great with the Trakt plugin.Have you had any chance to look at adding season and episode number into the info?
I already add this info but for another screen. Check it by pressing “Red” button. Or you are asking add it at first screen exactly?
