I have the same thing on Narcos. The episodes are in not in the right order. On all other Plex clients, even emplexer on Dune, shows the episodes in the right order.
What is it Narcos? is it Series name?
Yes, it is a Tv serie.
I’ll check
Which scanner do you use for series?
Hello jmper, I installed your plugin and everything works fine except that I can’t get a movie wall. The view is the same as when using the Dune without plugin.
Thanks!
Hello @Tomovich I guess you need install “system” storage
System storage is installed.
I have the emplexer plugin installed and there it works.
Which options do I need to change in DPC?
May be just select suitable screen (red button)?
Hello jmper,
I’ve just installed your latest versione and it works fine. Very good job. Just one question: when I select to sort per movie actors, Plugins works for a long time and ends prompting the message “Out of time” (or similar it’s a translation from italian language). Probably is a limitation of Dune because of too many items to show. In my server I’ve uploaded 16TB of data and actors are thousands.
Hello @StefanoP First of all congratulations!
And my questions: Do you use “names sort order” option? Do you use screen with actors photos?
I’ve tried with “First, Second” and “Second, First”; with Actors Photo and without. The result is the same: Connecting…Operation Out Of Time.
If I choose another sorting, like By Decade, By Directors, By year, by First letter…etc. It all works flawlessly; perfect and quick.
Hello jmper, this morning is all ok. I didn’t do anything. I’ve selected By Actors and after few seconds I saw list with actors thumbnails. Great.
I think I know the reason. Will fix in next update.
@jmper said:
It doesn’t matter how you will install plugin from usb or other drive. I think another app (Yadis) should not affect. Still wait log
Here it is. I can only see Plex folders like All Movies, Genre, erc. But when I click on it nothing happens.
One thing is strange. When Dune is turned on I don’t see the DPC icon until I select refresh.
Also on the USB key on the dune I only see the dpc.xml file and the log folder I just created. No other DPC plugin files…
As I can see you use old firmware (140610_0131_b8) And some functions gets error. Could you upgrade your dune?
It’s normal. Plugin’s files are inside dune fs, you can’t see them outside.
Thank you. I’ll upgrade my Dune to latest firmware and give it another try.
Ok we are making progress!
My issue now is I have the “Does not exist connection for…” when selecting a movie. Logs show
“Connection for \MyNASName\films2\NameofMovie\NameofMovie.mkv does not setup”
What is strange is this is not the path the Dune needs. That is the path the PMS uses from the pc. When I setup PMS I simply browsed to the network share on my NAS.
Dune needs the nfs path. Which I put in Connection Setup in DPC for every Movie ans Series PMS path listed. Example I entered
- protocol : NFS
- server : 192.168.1.5
- folder : /volume2/Films2
I don’t see this IP or path, which is my NAS IP and NFS path, anywhere in the Dune error logs…
Secondly,
I can browse movies, on the left I see the list and on the right one movie cover art at a time. Is this normal or can we have only cover art wall to browse?
Hello @phatboyc
Could you send me log file again?
Secondly,
Just press “Red” button on your remote to select suitable screen view
Red button worked to get a wall of cover art.
pm sent with my log file.
