In Series when I select “On Deck” it does nothing. All other options like “All” seems to work. Anyone else?
I don’t use “onDesk” but will try evening
@phatboyc really problem. I’ll fix it
Great, thanks.
i have my apex server running on a qnap nas. since my last update on the nas movies can´t start anymore.
dune says that the playback-list is empty. really strange. didn´t change any settings in dpc, either on dune, only the
nas has been updated.
@jmper: any chances that can you see in the log file what is going on?
Could you send me log file?
@boby31 said:
Hi jmper
When i go to plex section recently watched episodes
The listing begin with the oldest episodes and i have to scroll down the list to find the real lastest episode watched.It’s possible when i use this section to begin the listing by the end ?
++boby
Hello @boby31 I have just tried this filter and it works normally. The list starts with last watched episodes. Do you really use last plugins version? How does it work on web client?
Hi trying the plugin for dune as looks great
but I get an application error. Application caused an error and will be closed. Im unable to do any config etc as get the same error.
Dune prime 3.0, FM 150721_0135_b9 , dpc v1_071
After this failed I installed b1_03 and this worked OK.
Any ideas much appreciated
Same issue here, Application caused an error and will be closed. on Dune HD Max, latest firmware
Hello, can you send me log files?
Hi Jmper, I can’t PM you, can you PM me an email address please?
Cheers
logs have been sent, thanks
ok. I’ll check it
You need set your PLEX IP address (format: plex_ip:plex_port)
for example 192.168.1.25:32400
@phatboyc you can change “ENTER” button function in plug-in settings. Instead play it can show “info” screen with description and trailers (if exist)
:"> Sorry for such a basic error. Updated and all works well. Will have more play with it later!!
Many thanks
Oh that’s nice! Can’t wait to try it. I’m used to the Dune when Enter on the remote was always one thing and play another. I didn’t know your plugin had this option.
You can also press Info on the remote to get to the movie info screen.
I think the info screen could get a facelift though…
if you mean imorive info screen design - I can’t. It strictly defined by Dune. I can’t change even color and font size.
