Dune player
tcviper,
send me your emplexer.log.
I will tomorrow, sorry had to switch back to ATV for now and have no time this evening. Also it would be handy if you could describe what exactly needs to be done where.
  1. Add NFS share to the video files (nas/volume1/video) on Dune
  2. Add emplexer app on dune
  3. In emplexer app set to NFS and the IP of the plex server (macmini)
    Is that correct?
That's right , the only point is that currently emplexer expects this path is the machine on which the plex is installed , this is a problem I had not thought of , but do not worry I'll fix it :).
So we can’t have the PMS on one machine and media on another today. Is that correct?
Never mind. DL works agin…
Only if you use nfs, on http all work's.
I want to use smb.
it looks like you will have a solution for my problem (file not supported problem). but if it is to any help here is my emplexer log file
oh I forgot the log hehe
beat_strandh,
Your videos are on the same machine plex?
If yes , this directory is configured as an NFS share?
If yes , try setting your dune in a network path with this nfs address nfs ://192.168.1.103:/Volumes/dune/ and tell me if you can access your medias in nfs share.
Hi guys!!
I was wondering what plex server version are you all using. Currently I’m using 0.9.6.9 (Non web version), because I like the simplicity.
Im a PlexPass for life and love early stuff, even if they dont work :), so Im on 0.9.7.12.407.
Thanks for your reply.
I would like to use the latest version but I fined it annoying, I have to press alt to bring up the classic plex. I have requested many times to have a default option to open in classic mode, but it has fallen on deaf ears. :mellow:
Ok. I love everything so much more in the new PMS and the web intercafe is great. :slight_smile:
And it seems to work fine with emplexer too.
I have my videos on 2 places. the ones that works is on the same machine but the ones that dont is on a NAS.
btw, I tried BDMV and BD ISO but they didnt work. and those movies is on the same machine as the Plex media server. MKV and DVD-ISO works.
you can access the old style media manager and preference even with the new web based version. you just have to press a key (dont remember wich one) and at the same time click on the media manager/preference.
20mxm1 said in his post that he have to press the Alt key. :slight_smile:
haha Im tired
newloran2 when do you think you can have this update ready so i can set NFS to NAS and plex server to separate server?
If nothing goes wrong between now and tomorrow.
