Dune player
Emplexer was showing the episode summary, not the show. I’ve tried to find out, how it was done, but my php knowledge is pretty basic and emplexer code is somehow messy, so no luck yet :frowning:
I don’t have a disk in my dune, could I put it somewhere on system storage?
emplexer is showing episode info only if you run only one episode.
Try to use just flash stick if you dont’t have any other disks
I was always playing by one episode :slight_smile:
I have telnet access, so I’ve just uploaded it to system storage. DPC is using /D/ folder, so I put it there.
Hi jmper,
I’m also having this issue where it says invalid username or password even though they’re correct. I checked devices in the plex web interface and I don’t have dpc there to delete.
Any suggestions?
Great work on this plugin by the way.
Tim
@jmper said:
@Molika said:
@“Tanawat Tanaeksetkul” said:
Today I cannot sign in to Plex Account by DPC app in the set up section but I can sign in by my iPhone.
Is there anything wrong??
hi jmper, fantastic app and many thanks for putting time and effort in making it work with the dune players. the app works fine for me with one exception, similar to the issue above. i cant sign into my plex account using my credentials, i get an error message login and password are incorrect. i know I’ve got the correct details as it works on all my other clients and i logged in here as well but it just doesn’t work on the dpc. not a big issue but just wanted to mention it.
keep up the good work.
cheers
Hello, try to delete dpc from devices thought web browser and login again on your dune
Found couple of bugs related to playlists of TV episodes.
  1. If you’re click Play button on the playlist item, plugin crashes. Enter working fine, but (obviously) plays only one item.
  2. The info box doesn’t showing the show name (only episode title). It’s just empty.
  3. If prior to watching the playlist you’re watched some different TV Show, it’s name is inherited for all of the playlist elements. However, in the playlist show name is shown correctly.
Screenshots:
No show name
Show name in playlist
Show name in info box (I was watching Snowfall before)
Another bug, movies related. If using VOD playback, pressing Enter or Play on a movie crashes plugin. The Play button on the Info screen works, but it launches standard Dune playback, not VOD. The movie starts to play, then immediately stops and starts again by itself.
Hi jmper,
question: I am using DCP 1.3 version. The server version Version 0.9.15.2 and a bit outdated. Is it safe to update the server version?
Best regards,
Frank
Hello, don’t worry the plugin will work
I have a Windows homeserver 2011. I can see every movie on Plex, but. When I start them, I get a message that the file cannot be found. It works on other devices though.
I change the settings in Plex from Z:\serverfolders etc to //server/video’s and such. But no change for my Dune tv303d.
Anyone any idea?
Anyone any idea?
Can you mount the shares on your Dune?
Anyone any idea?
That I can. I have worked since the beginning with yaDIS and also have the shares connected as a fail safe on the sources page.
That all works without a hitch. As far as I can see, the string it gives me with the error is a directory structure which does exist.
It might be something silly. Maybe it cannot handle the ’ in video’s? That’s the only thing I can think of.
@Arunia said:
Anyone any idea?
Spaces are always problematic in linux. Try to avoid them when possible.
Otherwise try using “in videos”.
The ’ is also used as a text separator. There is probably is syntax like /’ or something to be able to still use them but also better to avoid using ’
@Arunia said:
Anyone any idea?
Could you do a screenshot of the DPC path settings? Hit Enter on any of the paths and grab a screenshot or photo.
Hi All, im very new to all of this plex thing and im still converting all of my movie files one by one from TS to MKV… a lengthy process!’ ive got 2 dune players an a hd 101 and a smart b1 id like to put this plugin on the 101, can someone please point me to a link for download and setup page? ive found it on github but the last entry is 4 years old…
Mark
www.jmper.ru/dpc/dune_plugin_dpc_v1.3a.zip
Hi Jmper,
I have Plex Server Version 1.8.1.4139 running on W10 Pro. It is working fine. I have local and remote access without any issues. I installed your 1.3a plugin on my Dune 4K Solo with the latest firmware. I configured your plugin and get list of movies and TV shows with proper thumbnails and posters. But I cannot play any of them. The same issue like others had. Dune doesn’t recognize the path provided when I try to run/play a movie. I’ve tried different settings in DPC connection: used SBM path, Mapped Dune folder. Nothing worked. I provided a log file, if you need it. I tried to analyze it by myself by comparing with other guys logs here, but it looks different. I think, because they use different Dune players.
Thank you for your work and the great plugin. I hope my issue will be fast resolved.
I had a former version working, and now I can not get the 1.3a version to save any of my connections. Is there a trick to getting the connections to save after editing them?
Hi Jmper,
Just brief follow up. Photos collection works fine. I can browse, do everything with photos. Looks like it uses different method for photos.
Nevermind about my saving issue. It seems that the most recent Dune firmware caused a problem saving the connections. I downgraded to a firmware from 2015 and had no issues saving the connections.
@fav2017 said:
Hi Jmper,
Hello,
you need setup your connections by Setup->Applications->DCP Setup->Connections
hi there! i just got an Solo 4k from birthday present, its completely new.
i install 2TB hdd inside and connect to internet and now i need PLEX PLAYER in it , so i can use my plex server at full power.
is there any COMPLETE (for dumb people like me) install instructions how to get it ?
