I now got it working plex 9.2.7 fixed it
Thanks, it worked for me, I had to delete out and re setup that section to get it working. Thanks heaps
Great plugin! Saved a lot of grief with my firefly episodes =).
worked for american dad, BUT when plex does an auto update, it changes it back to the wrong order, is there a way i can stop it updating just american dad?
tried to use it with Cheers, kept searching, but was always back on aired order. tried an unmatch, so blank thumbnails and everything, then did a match using tvdbdvd, searched for ages again, but came back blank again. I know there’s dvd order on the tvdb website cos i checked it… what’s going on there?
please someone help me… I can’t get it to work for any series at all, and I have a lot now that need to be DVD order. It’s driving me mad :’(
It’s working great ! (with Transformers
Thank you so much.
PS. I am using Plex v.0.9.3.3. and OSX Lion.
Having an odd issues.
Plugin install correctly…but when I change Firefly to the DVD order via the plugin, it rescans and matches Firefly to The Inbetweeners.
Even when I try “Fix incorrect match” it finds Firefly, but still scans it in as The Inbetweeners.
Any ideas?
-Kristijan
i’m curious, which is the most recent version? there are several to download throughout the thread.
also, i’m having an issue where it is pulling the correct episode title and meta-data according to the DVD Order, but the preview image is sometimes from the Episode Order, but not consistently.
Got this plug-in working great for Firefly, thanks so much! But I’m still having issues with ‘Batman the Animated Series’, when switching to the DVD order agent, and rescraping Plex then wants to treat Batman as X-Men the animated series, and rematching doesn’t display Batman in the choices. I could rename and number to the Aired order, but I’d prefer not to if there’s a work around.
Thanks again!
mikeisonthenets, I really have no idea what I’m doing wrong then, as I can’t get Firefly to work. It keeps scanning in as The Inbetweeners =/
Can you explain the steps you took to install the plugin please?
-Kristijan
It sounds like the first thing you have to do is get Firefly to scan correctly.
Could you perhaps describe the file hierarchy, and file names?
Or we can try this - Create a new user. Create a new teevee show folder(HDD/TV Shows/Firefly/episodes) that only has Firefly in it. From the new user account, let Plex do it’s thing and scan it. Copy the logs. Now add the DVD Order agent bundle, and ‘Match using’ and see what the results are.
SC
Hi Smithcraft,
Firefly scans in fine when I add it to my library (Aired Order), it's when I right-click, match using dvdorder where it scans in as The Inbetweeners. I don't believe it's an issue with the naming conventions, as I had this working in the past (About two weeks ago I moved my Plex Media Server to Macmini). Anyway, below is the way my files look.
[kristijan@nas /media/TV Shows/Firefly/Season 1]$ ls -l<br />
total 34319452<br />
-rw-r--r-- 1 kristijan staff 4695339464 Dec 30 2008 Firefly - S01E01 - [Serenity].mkv<br />
-rw-r--r-- 1 kristijan staff 2345689506 Dec 30 2008 Firefly - S01E02 - [The Train Job].mkv<br />
-rw-r--r-- 1 kristijan staff 2345039870 Dec 30 2008 Firefly - S01E03 - [Bushwhacked].mkv<br />
-rw-r--r-- 1 kristijan staff 2344837211 Dec 30 2008 Firefly - S01E04 - [Shindig].mkv<br />
-rw-r--r-- 1 kristijan staff 2345828652 Dec 30 2008 Firefly - S01E05 - [Safe].mkv<br />
-rw-r--r-- 1 kristijan staff 2338853190 Dec 30 2008 Firefly - S01E06 - [Our Mrs. Reynolds].mkv<br />
-rw-r--r-- 1 kristijan staff 2339087228 Dec 30 2008 Firefly - S01E07 - [Jaynestown].mkv<br />
-rw-r--r-- 1 kristijan staff 2338644632 Dec 30 2008 Firefly - S01E08 - [Out of Gas].mkv<br />
-rw-r--r-- 1 kristijan staff 2339081970 Dec 30 2008 Firefly - S01E09 - [Ariel].mkv<br />
-rw-r--r-- 1 kristijan staff 2339643030 Dec 31 2008 Firefly - S01E10 - [War Stories].mkv<br />
-rw-r--r-- 1 kristijan staff 2339807641 Dec 31 2008 Firefly - S01E11 - [Trash].mkv<br />
-rw-r--r-- 1 kristijan staff 2346739930 Dec 31 2008 Firefly - S01E12 - [The Message].mkv<br />
-rw-r--r-- 1 kristijan staff 2339723420 Dec 30 2008 Firefly - S01E13 - [Heart of Gold].mkv<br />
-rw-r--r-- 1 kristijan staff 2339565460 Dec 30 2008 Firefly - S01E14 - [Objects in Space].mkv
I'll give the other suggestion a try and try adding the server under a different user and report back.
Thanks,
-Kristijan
Well, they certainly are named fine.
Perhaps one other suggestion might be to remove the Season 1 folder and just have the files in the Firefly folder.
Ok, one more suggestion - remove the episode names also, so that the files are just ‘Firefly - s01eXY.mkv’
SC
I’m having a similar problem - all shows coming up as The Inbetweeners! (Currently I’ve just done x-files, dollhouse, firefly and TSCC)
Any ideas?
Rob
Thanks for this plugin, it has saved me countless hours of frustration in several cases. Mostly I blame Adult Swim for never releasing anything on DVD in the order they aired it :lol:
Hey
Any chance we can get the latest in .bundle as well to install on Linux?
Thanks!
JC
It does work on Linux: just add it manually to the Plug-Ins folder like on a Mac.
edit: okay, didn't see that it was only a .plexapp now.
Maybe a Mac user can retrieve it after installation as a .bundle, and share it here?
Thank you so much for this! I though i had to live with that annoying error in my playlist order, but you just made my day! I am really grateful that you made this so easy!
For some reason, I’m not seeing the plugin option when I select Firefly in the media server. I’ve tried both the app and the bundle. Any ideas?
