Hi, my antenna picks up both Canadian and American channels. During set-up only one postal code can be entered for epg data. The HDHR channel does this better by finding accurate data for all channels regardless of location. Can something like HDHR channel be implemented? About half my channels don’t show now because EPG can’t map. Thanks.
There’s no way for us to easily support a setup like this. There’s another thread where someones zip code worked for both, so maybe you can get lucky.
The other thing you could do is sign up for Schedules Direct and in their interface add as many lineups as you wanted, export a single XMLTV file which then you can import. It’s not ideal, but will serve as a workaround until we can figure out a better solution.
Didn’t know about schedules direct, will give it a try! Thanks for the prompt response
So I found a postal code that works. All 21 channels have a check mark, but one still won’t show up despite it being matched with Network Name. I see the listing for all shows on other channels, not this one. Any way to manually make this work?
@keithah said:
There’s no way for us to easily support a setup like this. There’s another thread where someones zip code worked for both, so maybe you can get lucky.The other thing you could do is sign up for Schedules Direct and in their interface add as many lineups as you wanted, export a single XMLTV file which then you can import. It’s not ideal, but will serve as a workaround until we can figure out a better solution.
sorry double post.
