DVR Commercial Skipping Broken
Server Version#: 1.30.0.6359
Hello, my DVR commercial skipping has stopped working over the past few weeks. I’ve ensured that option is still selected in settings and reset the server multiple times without success. Any tips to get it working again?
Thanks.
I have the same issue, also running the server on windows. Tried a restart without luck. Just updated to Version 1.30.0.6406, also changed the setting to Disabled, save, and back to Detect and Delete. Will see if any of this helped.
Found mention of this on a separate but related topic. Possible a recently updated version of FFmpeg is the issue. Reverting before 1.30 helped them.
Updated to server version 1.30.0.6406 and commercial skipping is still broken.
I have the same issue from October.
Commercial skip appears to still be broken. :frowning_face:
Have it set in the Plex server settings and on the DVR schedule. This has been set this way for years without issue. Always running the latest beta. Plex Web showing Version 4.87.2. General showing Version 1.30.0.6442.
Plex DVR team: Please fix. Ever since introduction, this has been the killer feature of Plex DVR.
Some more info here, change or wait I guess Commercial Detection Stopped Working - #2 by MovieFan.Plex
Thanks! Apparently the bug has been fixed for 32bit version now as well, but I just manually downloaded 64bit and will see how it goes.
Problem solved. Thanks Plex team!
