DVR fails to record a single, specific channel
Server Version#: 1.21.4.4079
Player Version#: 4.51.3
Tuner Make/Model: HDHomerun Prime HDHR3-CC
Guide/Lineup name: Charter Spectrum
Using XMLTV?: I don’t believe so (?)
Channel number/Name: 824 Fox Sports Midwest (HD FSN1)
I’m new to Live TV & DVR. It has worked great until Spring Training started and I tried to record the one thing I went back to a cable card for (as every streaming service dropped it), Fox Sports Midwest (824). I can click “Record” but nothing ever gets recorded nor can I navigate backwards if watching while it was supposed to be recording. It plays just fine, but won’t record. Scheduled recordings from this channel don’t show up on the “DVR Schedule” either. Every other channel I’ve tried works very well - I can hit record, cancel after a minute or so, and see the video in my library immediately on refresh. Note: This problem exists for every show that I’ve tried on Ch 824, not just baseball games.
A little suspicious that it appears to also be the only channel that doesn’t have an icon in the guide (although it should be the exact same icon from 826 which is successfully displayed) and instead just the text “FSM03HD”
Screenshot 2021-03-02 205759
There’s no unique flag on the channel like DRM. It is labelled HD like all the others on the HDHomerun Prime:
Screenshot 2021-03-02 210017
Below is a log chunk from the time period I attempted a test recording:
Mar 02, 2021 21:06:41.224 [0x7f5dceffd700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 02, 2021 21:06:41.235 [0x7f5df8ad8700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 02, 2021 21:06:41.239 [0x7f5dceffd700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 02, 2021 21:06:41.252 [0x7f5dceffd700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 02, 2021 21:06:41.258 [0x7f5df9ef3700] WARN - SLOW QUERY: It took 220.000000 ms to retrieve 81 items.
Mar 02, 2021 21:06:41.263 [0x7f5dceffd700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 02, 2021 21:06:41.289 [0x7f5df9ef3700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 02, 2021 21:06:42.072 [0x7f5dceffd700] WARN - QueryParser: Invalid field 'contentDirectoryID' found, ignoring.
Mar 02, 2021 21:06:51.506 [0x7f5dfaef5700] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 02, 2021 21:06:51.877 [0x7f5dceffd700] ERROR - Unknown metadata type: folder
Mar 02, 2021 21:07:01.109 [0x7f5dcdffb700] ERROR - Error issuing curl_easy_perform(handle): 7
Mar 02, 2021 21:07:01.442 [0x7f5df8ad8700] ERROR - Unknown metadata type: folder
Mar 02, 2021 21:07:03.598 [0x7f5d837fe700] ERROR - Unknown metadata type: folder
Mar 02, 2021 21:07:03.894 [0x7f5dcf7fe700] WARN - QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Mar 02, 2021 21:07:03.950 [0x7f5df9ef3700] ERROR - Unknown metadata type: folder
Mar 02, 2021 21:07:04.071 [0x7f5d7a7fc700] ERROR - downloadContainer: expected MediaContainer element, found html
Mar 02, 2021 21:07:04.071 [0x7f5d7a7fc700] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:5/metadata/plex%3A%2F%2Fshow%2F5fc6aa6c3f000e002df56366
Mar 02, 2021 21:07:04.149 [0x7f5d81ffb700] WARN - QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 02, 2021 21:07:07.391 [0x7f5dcf7fe700] WARN - QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 02, 2021 21:07:07.407 [0x7f5df8ad8700] ERROR - Unknown metadata type: folder
Mar 02, 2021 21:07:07.675 [0x7f5dceffd700] WARN - QueryParser: Invalid field 'libraryHubsOnly' found, ignoring.
Mar 02, 2021 21:07:07.688 [0x7f5dcf7fe700] WARN - QueryParser: Invalid field 'sectionID' found, ignoring.
Mar 02, 2021 21:07:07.693 [0x7f5d81ffb700] ERROR - Unknown metadata type: folder
Mar 02, 2021 21:07:07.872 [0x7f5d787f8700] ERROR - downloadContainer: expected MediaContainer element, found html
Mar 02, 2021 21:07:07.872 [0x7f5d787f8700] WARN - Subscription: No container available for /tv.plex.providers.epg.cloud:5/metadata/plex%3A%2F%2Fshow%2F5fc6aa6c3f000e002df56366
Things I’ve tried and had the same (lack of) success with:
  • Recording while the show has already started
  • Scheduling individual items on the guide
  • Scheduling “All St. Louis Cardinals Events”
  • Doing all these types of scheduling from different devices (Web, Shield TV, Android)
Please, if anyone can help or point to a workaround it would be greatly appreciated. I was really stoked about this solution until it didn’t work for really the only thing I care about. Thank you.
FWIW I resolved this by enabling the transcoding setting on the DVR. Not sure why that resolved it, but I ultimately re-created the DVR after that once again and left the transcoding setting disabled - this time it worked… I don’t know.
As an aside: anyone know how to add a channel image if one is missing? I don’t really care about the guide image but it leaves the Recent Channels thumbnail in the What’s On section blank as well.
