DVR (local) Playback Issues - Gets stuck rewinding and restarts playback
Server Version#:1.23.2.4625
Player Version#: 8.17.1.25326
Setup: - Watching a show recorded locally on the shield, using the DVR, to watch it locally on the shield.
Summary of Issue: Pressing rewind 10 seconds (single press of the ‘back’ button) seemingly locks the player and no feedback is provided after 3 minutes, see attached WorldsFunniesPlaybackIssuesShieldPlayer.txt. So you go out and come back in again… decide you want to go back 10 seconds again and it again locks up so you go out and come back in again. However, this time it decides that playback needs to be restarted from the beginning instead of 10, or so, minutes in.
Why is it trying to leave the shield to get the information it needs:
06-06 04:53:21.683 e: An exception occurred: java.net.SocketTimeoutException: failed to connect to / (port 32400) from / (port 49244) after 5000ms
06-06 04:53:21.684 e: Stacktrace: java.net.SocketTimeoutException: failed to connect to / (port 32400) from / (port 49244) after 5000ms
at libcore.io.IoBridge.connectErrno(IoBridge.java:185)
at libcore.io.IoBridge.connect(IoBridge.java:129)
Plex Media Server.log (703.5 KB)
WorldsFunniesPlaybackIssuesShieldPlayer.txt (1.0 MB)
