DVR loses channels
Server Version#: 1.24.5.5173
Tuner Make/Model: HDHomeRun HDTC-2US & HDHomeRun Flex 4k HDFX-4K
Guide/Lineup name: Local Broadcast Listings
Using XMLTV?: No
Channel number/Name: NA
This previously worked with no issues. In the more recent release of plex it’s broken. Recently I had tested using an xmltv feed from xteve, but reverted back to the standard HDR EPG. This works on initial run detects 45 channels, but the next day it shows only 1 channel but nothing is selected. I’ve tried manually mapping the channels and save, again the next day it reverts to 1 channel with nothing selected. If I delete each of the hdr’s and re-add they work till the next day.
Not sure what’s going on but it’s pretty frustrating.
plex-dvr
A lot of people are having problems with plex dvr & live TV since 1.23.some. I‘ve also tested a lot with different versions and deleting database infos and so on but was not able to fix it.
I now reverted back to the latest 1.22 version and dvr is working fine again.
