LiveTV Dropping Channels
Server Version#: 1.20.3.3437
Player Version#: 4.44.2
Tuner Make/Model: HDHomeRun CONNECT
Guide/Lineup name: IceTV
Using XMLTV?: Yes
Channel number/Name: All channels.
Is anyone else having issues with Plex dropping their channels a little while after they have been added. Started a couple of weeks ago, where all my channels bar 1 dropped off, edit the LiveTV and the channels are still there but the matching to the EPG were lost.
Removed the DVR and restarted the server, same process same result. Upgraded to the latest beta today, same process and same result.
Fixed the issue. Had DizqueTV pushing channel updates to it. Turned that off and it was fixed.
Thank you for following up with your solution! I’ve been beating my head against logs for weeks with this exact issue. Totally forgot that I had dizque running but had never gotten around to actually configuring it.
