DVR moving recordings to an invalid location
Server Version#: 1.41.1.9057
Tuner Make/Model: HDHomerun
Server OS: Ubuntu
I’m having a bit of an odd issue. My DVR was previously set up to record to /mnt/cloud/nt-dvr, a folder that I mount from my NAS and it worked just fine. However, I got an external drive to record to and have since been trying to record to /mnt/dvr/tv.
For some reason, once I added this to my DVR Library, it resulted in recorded tv being recorded to /mnt/dvr/tv/.grab, as expected, and then resides at /mnt/dvr/tv for about a day. But, after a few hours, not more than a day, then it is being moved by the plex server to /mnt/nt-dvr/, which is not what I’m looking to do. Interestingly enough, that was never a folder I had as part of the library at all.
My first idea was something got messed up with the destination folder for the recordings, so I added /mnt/nt-dvr/tv to the library and went through each recorded show, one by one, and made sure they are pointing to /mnt/dvr/nt. However, the issue persists.
If I look in the Plex Media Server.log file I find lines like this:
Plex Media Server.2.log:Nov 10, 2024 13:45:17.452 [140060241849144] INFO - Part rename detected [/mnt/dvr/tv/The ReidOut/Season 2024/The ReidOut - S2024E226 - Episode 226.ts] was renamed [/mnt/nt-dvr/tv/The ReidOut/Season 2024/The ReidOut - S2024E226 - Episode 226.ts]
You can see that it is recording to /mnt/dvr/tv as intended, but then being moved to this mysterious /mnt/nt-dvr/tv folder. I tried dumping the various .db files and then grepping them for nt-dvr to no avail. Any ideas on what is going on here?
Alright, no idea what the issue was, but deleted the tuner and the issue is gone. \o/
