DVR Questions
I have a couple of questions about the DVR feature:
I use a Silicon Dust HDHomeRun EXTEND
  1. I no longer see Live TV as a feature to select on the Plex home page. Where did it go? My server software is up to date.
    2, I was on Silicon Dusts page to get software updates and check some things and saw that there is a $35 annual fee to enable the DVR software function on the device. Do I need to pay this to allow for functionality through PLEX? Can’t remeber if I have in the past.
Thanks for any help you can provide,
Stewrt
  1. look under MORE at the bottom of the side bar. You can ‘pin’ it back on the side bar from there.
  2. No. This only applies when using the tv app from Silicon Dust. The fee for the EPG data is included in your Plex Pass.
Thank you Otto!
