DVR Recording and Live TV failures in 1.25.2.5319
Server Version#: 1.25.2.5319
Player Version#: 4.72.0
Tuner Make/Model: tvhProxy
Guide/Lineup name: Freeview (148 channels)
Using XMLTV?: No
Channel number/Name: Various
After updated to 1.25.2.5319 from 1.24.5.5173 on macOS, DVR recordings are failing and trying to watch live is failing with the error “Error code: s1001 (Network)”.
Sometimes it will play successfully after several attempts, but it is failing more times than it is succeeding.
I rolled back to version 1.24.5.5173 and playback and recording started working as expected.
I also tried installing version 1.25.1.5286 instead (which I believe is the version previous to 1.25.2.5319) and I still have this issue, so it doesn’t look like this issue started with version 1.25.2.5319.
Edit: Found the following in the logs which look like they may be related
Jan 01, 2022 10:11:31.260 [0x70000b570000] ERROR - [Grabber/5fc76db29df53e002dbab94a-5fc705fea62668002dcefe6c-r2ebbddbhled0d865iege6fq] Unknown metadata type:
Jan 01, 2022 10:11:31.632 [0x70000b988000] ERROR - [Transcode] MDE: video has neither a video stream nor an audio stream
Jan 01, 2022 10:11:31.632 [0x70000b988000] ERROR - [Transcode] Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
Jan 01, 2022 10:11:31.777 [0x70000bc17000] ERROR - [Transcode] MDE: video has neither a video stream nor an audio stream
Jan 01, 2022 10:11:31.777 [0x70000bc17000] ERROR - [Transcode] Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
Jan 01, 2022 10:11:31.777 [0x70000bc17000] WARN - [Transcode] Failed to obtain a streaming resource for transcode of key /livetv/sessions/1df5a17e-23be-410b-86a1-67a5a4d3b8a3
Jan 01, 2022 10:11:32.606 [0x70000b988000] ERROR - [Transcode] MDE: video has neither a video stream nor an audio stream
Jan 01, 2022 10:11:32.606 [0x70000b988000] ERROR - [Transcode] Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
Jan 01, 2022 10:11:32.606 [0x70000b988000] WARN - [Transcode] Failed to obtain a streaming resource for transcode of key /livetv/sessions/1df5a17e-23be-410b-86a1-67a5a4d3b8a3
Jan 01, 2022 10:11:32.662 [0x70000b3e7000] ERROR - [Transcode] MDE: video has neither a video stream nor an audio stream
Jan 01, 2022 10:11:32.662 [0x70000b3e7000] ERROR - [Transcode] Streaming Resource: Cannot make a decision because either the file is unplayable or the client provided bad data
Jan 01, 2022 10:11:32.662 [0x70000b3e7000] WARN - [Transcode] Failed to obtain a streaming resource for transcode of key /livetv/sessions/1df5a17e-23be-410b-86a1-67a5a4d3b8a3
Jan 01, 2022 10:11:32.663 [0x70000c653000] WARN - Could not convert "state" ("error") to the correct type
Jan 01, 2022 10:11:47.558 [0x70000ba8e000] ERROR - Network Service: Error in advertiser handle read: 89 (Operation canceled) socket=101
I think I’ve solved this myself.
I had tvhProxy configured to use the default pass profile (MPEG-TS passthrough) in TVHeadend.
After adding a new MPEG-TS/av-lib profile to TVHeadend and configuring tvhProxy to use this, it now appears to be working even in the latest version of Plex at least for live TV. I have some recordings scheduled for today so I’ll know later if those are also working.
HDHomeRun PRIME HDHR3-CC
FirmwareVersion: 20210624
HDHomeRun SW for Mac: 20211212
PLEX Media Server: 1.25.2.5319
MacOS: 12.1 (21C52)
While I am using HDHomeRun Prime as tuner, I have similar problems that also seem to point to a change introduced with 1.25.x.xxxx. Live TV and DVR functionality was restored when I rolled back to 1.24.5.5173.
UPDATED: 2022-JAN-02: Rollback did not resolve the problem. Server Logs available via PM.
Detailed Description:
(also posted in SiliconDust Forum)
When using PMS version 1.25.2.5319, PLEX and the HDHomeRun software (Mac) cannot maintain a connection to the Prime’s tuners. After restarting the Mac, Plex “Live TV and DVR” service works normally and so does the HDHomeRun software (Mac). I am able to tune channels, set recordings etc.
However, after a period of time (ranging from minutes to hours), both Plex and HDHomeRun seem to lose their connection to the tuners. Selecting a channel in Plex results in an error “Playback Error Could not tune channel. Please check your tuner or antenna” and rescheduled recordings fail.
The HDHomeRun software opens to the “Recordings” tab but with no other tabs available. If I try to use “hdhomerun_config [deviceID] set /sys/restart self” it will report “no device found”.
Interestingly, I was able to:
• ping the HDHomeRun Prime;
• access the HDHomeRun Main Menu via its IP address;
• discover the HDHomeRun via http://ipv4-api.hdhomerun.com/discover.
I also noticed that when the tuners are lost, the SpeedTest app will fail to locate a nearby server and report that the Mac is not connected to the internet. However, I can access and use the Speedtest via Ookla’s website as well as Fast.com. Its the strangest thing.
Similar problem with HDHR HDTC-2US Extend with Firmware 20210624.
Getting from the HDHR log file Tuner: invalid channel 4.1 News4
HTTP: rejecting request from 192.168.0.xxx - tune failed.
Plex Logs (Plex Tuner Service.5.log from Nov 24,2021 Plex Media Server\Resources\Tuner\Shared" 1.25.0.5246 -cb2507e4d 32600
(Plex Tuner Service.log from 1/1/2022 - Shared" 1.25.2.5319 : get SAT2IP discover_satip_servers(): no servers found
BDA DeviceGetListEx_impl. Skipped Siliconndust virtual BDA driver
DeviceGetListEx_impl: filter [Silicondust HDHomeRun Tuner 105153D4-1]
[I] file_tuner: get_stream_file. File C:\ProgramFiles (x86)\Plex\Plex Media Server\Resources\Tuner\Private\devices\dvb\file\drv_file.ini does not exist
This repeats several times as different channels were tried.
I put an older HDHR connect 2 tuner device in with similar results.
Any help appreciated. Cannot record or View any OTA channels .
I can use the HDHR configure and View any of the channels that are active on my PC. Something has changed during the
It seems that the issues I was experiencing were due to SOPHOS Home.
I contacted SOPHOS HOME Support on 3 December. They advised me to add “web exceptions” for the local loopback address (127.0.0.1) as well as for the local IPs of the affected devices (in my case, the HDHomeRun Prime and the Plex Media Server).
After a re-start, DVR Recording and Live TV are working normally since Friday 7 December.
Hi, did this resolve the issue for you?
I have the same Freeview, tvhproxy and tvheadend configuration and am seeing randomly that some recordings and/or LiveTV are sound only and when I check the logs I see
Feb 16, 2022 15:31:06.635 [0x152c215f4b38] DEBUG - [Transcode] MDE: video has no video stream but does have an audio stream
I’ve just tried what you suggested now and will see how I get on myself…
It did resolve the issue, but I sometimes found that I would get occasional dropouts in the recordings (video and audio) possibly due to the conversion process.
I’ve now created another new profile of the type “MPEG-TS Pass-through” which is the same as the standard pass profile but with these options turned off (the view level needs to be set to Expert to see those options):
  • Rewrite PMT
  • Rewrite PAT
  • Rewrite SDT
  • Rewrite EIT
Those options rewrite certain packets in the stream to only refer to the currently streamed service, which looks like it may cause issues with Plex.
Plex appears to be working with this profile, and I haven’t noticed any dropouts but I’ve not recorded much since making this change.
Ah OK, thanks for that extra information, I will give that a go also.
How did you figure out to try all those options, trial and error?
The av-lib profile was based on a suggestion I had seen elsewhere, but can’t remember where now.
The modified passthrough profile was really just trial and error. I just decided to create a custom profile based on the existing pass profile and experimented with what changing different options did.
Just wondered how you are getting on with the pass profile and the rewrite options turned off?
I still see a lot of problems with Live TV not starting (spinning circle) or starting without sound, and failed DVR recordings.
Part of the issue could of course be the poor FireTV Android client…
