1.13.8.5395 - "There was a transcoder error" - I can't record anything
Server Version#: 1.13.8.5395
Player Version#: N/A
Neighbours - recording started at 10:54:30am, failed about 30 seconds later with “There as a transcoder error”. I’m also unable to watch live tv at all. I’ve restarted the computer and confirmed that my usb tv tuner is still showing up.
I had this issue when I initially upgraded to this version (plex pass beta), so I uninstalled and went back to an older, stable version and also set myself back to public updates only. It was just released to the public today so I assumed it would be better.
I have also confirmed that I am up to date with my windows updates.
Plex Media Server Logs_2018-09-25_10-57-21.zip (3.6 MB)
Yep same problem just updated to Version 1.13.8.5395 public not beta, live TV or recording does not work at all on Hauppauge WinTV-quadHD
Forgot to mention, I have Hauppauge WinTV-dualHD
Sameissue: transcoder error. Using HomeRun Connects. Using latest update.
Similar for me with the WinTV Dual
Whatever changed in 1.13.8 has made it a lot more unreliable
reverting back to 1.13.7 and everything is fine, 1.13.8 and recordings either fail after 30 seconds or things just dont record
Ditto using Hauppauge quadHD
How did you revert to previous version. By uninstall current one and then install previous version. Or there is simpler process, because i can not execute installation by .exe of previous version unless current is removed.
Yep, you just need to uninstall and then install an older version, you need to have a copy of an older version though.
Thanks for confirming it exactly what I thought. Will just wait for new update (hopefully will come soon).
Ok I decided to do a clean install of 1.13.8. “Transcoder error” still there; will not allow any DVR recording. Going back to older version.
Anyone know how to download the 1.13.7 update. My latest I saved is from March 2018.
I’ve heard that you can check your Web Updates folder (or something similar), apparently it keeps previous versions in there. I haven’t used this method myself because I run it as a service and manually download updates.
Found it…Thanks…
On windows 10, previous versions are in
C:\Users\cedric\AppData\Local\Plex Media Server\Updates
If I unistall and reinstall an older version, will I have to re-enter all my recording scheduling, channel customizations etc? Or does Plex keep them somewhere safe like in the DB.
In my experience if you uninstall your current version and then install an older version everything is retained. I’ve only ever gone back 1-2 versions though.
Does anyone have any word at all from Plex on this? It seems that this latest version has completely broken DVR recording and there desn’t seem to be any rush to issue a quick fix, or even to acknowledge the problem.
Fortunately I managed to find the prior version’s installed in the updates folder to roll-back my “initial proof of concept” PMS on my Windows PC, (using a Hauppauge quad-HD card).
But having had to hurry up the timeline (for other reasons) for building my “proper” server - on a Synology NAS using HDHomeRun tuners - that is of course also completely broken for DVR recording, and the only older version I could find to roll-back to is the 1.13.4 package in the Synology repository… which from early tests seems to have some stability issues itself :frowning:
It’d be nice to at least know that the problem is acknowledged, and a rough ETA of when a new version including a fix might come out!
It would be great to know! If any plex employees can comment that would be great.
Me too. Recording became unreliable. Transcoder failures.
I uninstalled the dvr. Now can’t re-add it. USB hauppage dual. Even after trying the haulage win 10 anniversary driver update.
Bah.
Having the same issue with 1.13.8.5395 I have a WinTV Quad HD also. I had it working on an earlier verion, but I had to limit it only one DVR. If I have the 2 DVRs added for all 4 tuners, it has transcoder errors every time. Will uninstall and reinstall an earlier one and hope for the future.
I expected the Plex DVR features to work as advertised, so far it has been a struggle to get it to work at all.
Ive got same issue. DVR and live TV completely broken in 1.13.5395. Ive now got massive gaps in my recordings because nothing has recorded since 24 Sept. Really really annoyed - this version is released now too so I have to question testing and quality procedures.
Uninstalled and put in an earlier version - still no luck. Plex does not seem to be a reliable program to use as a DVR. Time to look for something else.
