DVR-recording fails sporadically
Server Version#: 1.25.1.5286 - 1.25.2.x
Player Version#: Web 4.71.0
Tuner Make/Model: Fritz!Box 6490 Cable (4 Tuner)
Guide/Lineup name: NetCologne (400)
Using XMLTV?: no
Channel number/Name: any
Hi there,
my recordings fail sporadically.
But if you quickly delete the start of the recording 1-2 times and repeat it, it works.
I have the feeling that the timing of the tuning is too tight here. In other DVB tools I have seen that a timeout of up to 2000 (TVheadend std 50ms is faulty) - 4000 (DVBViewer) ms is set and it works reliably.
How long is the timeout at plex?
See logs also here
https://forums.plex.tv/t/dvr-recording-fails-sporadic/758859
New Log:
recording started at 19:02:00 (ALF)
recording failed at 19:02:08
immediatly edit the schedule to “Allow partial airings”
recording started at 19:02:20
PMS Logs_2021-12-14_19-02.zip (287.2 KB)
Dec 14, 2021 19:02:08.613 [0x7fe59bae4b38] DEBUG - Request: [127.0.0.1:33928 (Loopback)] PUT /video/:/transcode/session/0edcab22-e771-4118-baf0-7ffa89b0069b/d1f56623-bc25-4c82-b4c0-1bf7e3d8c243/progress?duration=-1.000000 (17 live) Signed-in Token (OLeutz) (range: bytes=0-)
Dec 14, 2021 19:02:08.613 [0x7fe59c6cab38] DEBUG - [Grabber/9af4f6efbd43b0f8561c3f3db5ba4a96fc2e034d] Using default transcode duration of 120 minutes
Dec 14, 2021 19:02:08.613 [0x7fe59c6cab38] DEBUG - [Grabber/9af4f6efbd43b0f8561c3f3db5ba4a96fc2e034d] Started session successfully: 0edcab22-e771-4118-baf0-7ffa89b0069b
Dec 14, 2021 19:02:08.613 [0x7fe59e584b38] DEBUG - Completed: [127.0.0.1:33928] 204 PUT /video/:/transcode/session/0edcab22-e771-4118-baf0-7ffa89b0069b/d1f56623-bc25-4c82-b4c0-1bf7e3d8c243/progress?duration=-1.000000 (17 live) 0ms 203 bytes (pipelined: 10) (range: bytes=0-)
Dec 14, 2021 19:02:08.613 [0x7fe59c6cab38] DEBUG - [Grabber/9af4f6efbd43b0f8561c3f3db5ba4a96fc2e034d] Recorder: It took 4.1 sec to start the session for http://127.0.0.1:32600/devices/dvb%23sat2ip%233%23uuid%3a663d5d6c-f9f8-4bb4-84d4-E0286D49BBE0/media/triplet%3A%2F%2F777%3A7900%3A12061?param=%3C%3Fxml%20version%3D%221%2E0%22%20encoding%3D%22UTF-8%22%3F%3E%0A%3Ctunedata%3E%3Ctt%3E2%3C%2Ftt%3E%3Cdq%3E0%3C%2Fdq%3E%3Cdr%2F%3E%3Cfr%3E498000%3C%2Ffr%3E%3Cmd%3E0%3C%2Fmd%3E%3Csr%3E6900000%3C%2Fsr%3E%3Cpl%3E0%3C%2Fpl%3E%3Clf%3E7%3C%2Flf%3E%3Cl1%3E0%3C%2Fl1%3E%3Cl2%3E0%3C%2Fl2%3E%3Cls%3E0%3C%2Fls%3E%3Cpp%3E0%3C%2Fpp%3E%3Chz%3E0%3C%2Fhz%3E%3Cin%3E0%3C%2Fin%3E%3Cfc%3E0%3C%2Ffc%3E%3Ct%3E7900%3C%2Ft%3E%3Cn%3E777%3C%2Fn%3E%3Cs%3E12061%3C%2Fs%3E%3Cen%3E0%3C%2Fen%3E%3C%2Ftunedata%3E%0A
Dec 14, 2021 19:02:08.614 [0x7fe59be6cb38] ERROR - [Transcoder] [mpegts @ 0x7fc3be634040] sample rate not set
Dec 14, 2021 19:02:08.614 [0x7fe59bb1db38] ERROR - [Transcoder] Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument
Dec 14, 2021 19:02:08.615 [0x7fe59bf63b38] ERROR - [Transcoder] Error initializing output stream 0:3 --
Dec 14, 2021 19:02:08.616 [0x7fe59bae4b38] ERROR - [Transcoder]
Dec 14, 2021 19:02:08.618 [0x7fe5a00c9b38] DEBUG - Jobs: '/volume2/@appstore/Plex Media Server/Plex Transcoder' exit code for process 13347 is 1 (failure)
Dec 14, 2021 19:02:08.618 [0x7fe59b943b38] DEBUG - Killing job.
Dec 14, 2021 19:02:08.618 [0x7fe59b943b38] DEBUG - Signalling job ID 13347 with 9
Dec 14, 2021 19:02:08.618 [0x7fe59b943b38] DEBUG - Job was already killed, not killing again.
Dec 14, 2021 19:02:08.618 [0x7fe59b943b38] DEBUG - Stopping transcode session 0edcab22-e771-4118-baf0-7ffa89b0069b
Dec 14, 2021 19:02:08.618 [0x7fe59bb89b38] DEBUG - Streaming Resource: Terminated session 0x7fe59f969938:0edcab22-e771-4118-baf0-7ffa89b0069b with reason Recording failed. Please check your tuner or antenna.
Might as well get used to sporadic failures. They’ve happened for years and never been addressed. What’s worse is they disappear from the schedule log so you don’t even know they’ve failed if you don’t watch closely. You just notice it when all of a sudden you’re like … wait where is this random episode?
Have you tried deleting all of the files in the codecs folder? In three years of Plex OTA recording I’ve been pretty solid expect for two instances where I would get failures when recording multiple shows concurrently. In both cases deleting the codec files resolved the problem for me.
The codec folder is a subdirectory of the Plex data directory. (I’m running on a Linux server, not a NAS, so yours will be in a different location than mine.) I typically stop the Plex Server service, delete the files in the codec folder (not the folder itself), and then start Plex Server. Plex will re-download the codecs as needed.
Ok, so this is from my Synology NAS (DSM6)
this is windows (test-VM)
