Server Version#: 1.40.0.7998
Player Version#: 1.86.1.4076-a3ab948d (Plex for Mac)
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Guide/Lineup name: Freeview
Using XMLTV?: Not knowingly
Channel number/Name: Dave
I have a few recordings setup on Freeview (UK) which record fine, get the program information ok (further details below), but are recording duplicates of what’s already in my TV Show library.
So I know the duplicates appear because the TV Shows library matches one instance of the show, but the DVR matches against the same show but with a different description/poster image (same program, but different version of the poster).
My TV Shows library is using the ‘Plex Series’ agent and the local files for the series in question match the poster found on themoviedb.org.
I’m trying to find out where the DVR version of the match comes from so I can match my local files to it and hopefully stop the duplicates. I’ve tried searching tmdb, thetvdb etc but cannot find the version of the poster that the DVR recordings match against.
Any ideas?
Cheers!
M
