plex dvr running on Ubuntu 16.4.
version 1.9.2.4285
hdhomerun prime tuner
viewing devices amazon fire tv, hard wired to network, no wifi
my recordings have strange bars that it’s hard for me to explain. it’s like horizontal small bars around the edges of objects. I’ve attached an image. when viewing, the status on the video is as follows:
converting throttled
video direct stream
audio direct stream
Thanks for your reply. Upon your telling me the issue, I did some research and it appears its a major issue with interlacing and amazon fire. I’ve not used it like this before but its a bit of a bummer and i just moved everything to work on amazon fire from my xbox one…doh! thanks again.
@rhltechie One option is to transcode the recording to deinterlace the video. I am running on Windows 10 and use MCEBuddy (which in turn using handbrake, ffmpeg, and comskip) to transcode and remove commercials. Since you are on Ubuntu, there are scripts/guides that users talk about in the forums to handle this task. You could either keep the same quality and deinterlace or in addition you could compress the file, saving space.
