Hello
my TV-Recording stops after around 10s after it starts recording. File creation works but there is an empty .ts file. I tried different File location for recorder output, but every time the same issue. Recordings worked normal last week, nothing has changed.
Please Help.
I am using Windows PMS on Win10Pro 1903 i5-2320 3.00GHz, 12GB RAM, GeForce GTX 560Ti
DVR Card: Hauppague WinQuadHD PCI-Express
It would help if you could post your PMS logs that cover the time of failure. Make sure the debug is ON and that verbose is OFF.
I attached the Log during one minute the error happened. (two DVR records where running while a third one started. This third recording was not started properly so it has stopped right after.
Maybe one of this four Tuners do not open correctly?
DVR LOG.txt (281.7 KB)
Hi all,
Got the same issue since a few weeks. Deleted the DVR yesterday and set up a new DVR. So my assumption was, that everything should work fine beginning at 12-Feb.
Attached the log file.
Plex Media Server Logs_2020-02-12.zip (701.1 KB)
