Hello,
I’ve had this problem for the past month on and off. The only channel I am having this happen with Animal Planet HD for verizon fios. I have reported it via the spreadsheet in the sticky above for EPG repeatedly . Is this ever going to get resolved? I have no other problems with any other channel? I look forward to hearing from you.
You can always use the Minutes Before Start option for the show to start 1 minute early. This is what a lot of users do to ensure they do not miss the start of the show. Plex starts the process to record a show at the start time for the show.
If they report the show is starting at 8:00 and don’t start it until 8:00:15 there is not much Plex can do about it. You will get whatever they are broadcasting from 8:00:00 until 8:00:15. Plex just requests a stream on the channel from your tuner device at 8:00 and records whatever the channel is broadcasting until the end time for the show reported in the EPG.
That’s what pre and post padding is for. I use 2 minutes for EVERYTHING unless it’s a sport show that could run over then the post padding is much longer. (and adjust shows that come on AFTER sporting events).
