DVR Script Location Help
Server Version#: 1.19.5.3112
Tuner Make/Model: HDHomerun
Can anyone help with what format listing like txt, bat, etc, should be put in the box for post-processing?
Do I just put the filename in?
Do I put the full directory?
Do I skip the extension?
What formats are supported for scripts?
thanks
